Old 10-16-2018, 09:19 AM   #1
Tire Blown Unknown
Hello fellow travelers,
So, my wife were traveling from Prineville, OR to North ID a few weeks ago. We stopped in Madras for gas and pulled into Les Schwab to have air checked on TT, a 21 Mini-lite, and 2011 F150. All was good. About two hours later we were heading down the 84 towards Umatilla when a passerby flagged us down alerting me to a problem.
I pulled over and discovered a blow out on the rr tire the tire was shredded to the rim! Fortunately, the whipping tire did not damage the cabin, and damage to the tire skirting was minimal. I ave two questions to this problem: How could I not know this happened? Is there a tire pressure monitoring system I can install and connect to tow vehicle?
Thanks all.
Lukkydog is offline   Reply With Quote
Old 10-16-2018, 10:39 AM   #2
fonzie's Avatar
You can install a TST507 TPMS......
https://www.google.com/search?q=tst5...iverforums.com
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 10-16-2018, 11:23 AM   #3
Head Rambler
There are plenty of TPMS (Tire Pressure Monitor Systems) out there for towed vehicles. TST is very popular here.
Having said that, the TPMS won't do anything for a catastrophic failure, but it will let you know that it's happened shortly after the incident.
Gotta go campin!
Old 10-16-2018, 11:55 AM   #4
Pure speculation here: perhaps the tire shop lowered the air pressure on a warm tire to the cold inflation spec. This would result in an under inflated tire and blow out.
I run the TST tpms system and love it.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2018: 24 nights camped
Teamfour is offline   Reply With Quote
Old 10-16-2018, 12:00 PM   #5
Pure Speculation
I find the situation coincidental. We had traveled from Central Coast CA to OR with no problem. Wife suspects the tire place. I will look into the TST. Thanks everyone; I got what I need!
Old 10-17-2018, 02:40 PM   #6
Lins's Avatar
It's definitely suspicious, and I know a lot of people think that's what should be done. I would be calling and asking what exactly they did. I always check/fill/rotate tires myself. I also run a TST.
2007 Rockwood 2701SS
2014 Triumph Bonneville. NH Togas, TTP Tune 3
1953 GMC 9314
Lins is offline   Reply With Quote
Old 10-17-2018, 04:23 PM   #7
NMWildcat's Avatar
Never trust anybody to set air pressure on your tires. Check and adjust yourself when cold.
Any tire shop knows not to adjust warm tires down in pressure. And whether they did or not is a moot point now. You can't prove or disprove anything.
Chalk it up to coincidence and lesson learned.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 10-17-2018, 04:41 PM   #8
(Dry Huunday)
DreiHunde's Avatar
This^^^
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 10-17-2018, 06:29 PM   #9
X2 on TST 507.
spock123 is offline   Reply With Quote
Old 10-17-2018, 06:56 PM   #10
Never adjust pressure on hot tires. You need a TPMS and then you will be able to see a tire going down. With a lighter trailer you may not even notice a flat tire. I had a tire valve start leaking the other day after adjusting pressure. I guess the valve didn't seal correctly. Put the chuck back on and took it off again and it was ok. If I had not have heard it I would have had a leaking valve going down the road. A TPMS would have warned me when the pressure dropped.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
tire
