Old 06-27-2016, 09:14 PM   #11
BandJCarm's Avatar
I-40.......around Jackson, TN today............a Coleman TT on side of road on west bound side (I was headed E.)..........with a wheel and NO tire. Blue lights everywhere. Three separate places behind him were fire trucks spraying down the median and ditch.
Clearly he blew up a hub and caught it on fire, tire parts on fire headed to weeds, and a big old mess.
There but for the Grace of God go I..............
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 06-27-2016, 09:24 PM   #12
Hankook RA08. 195R14 because they are 195/82R14 instead of /75. If you have a Discount Tire or one of their sister companies near you can get them quick.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 06-29-2016, 05:04 PM   #13
I replaced my 205/75 R14 bias ply tires with Taskmaster 215/75 R14 tires which are D weight rated at 2200# per tire and are speed rated M (81MPH). So far they are great tires. I would recommend them.
POS Camaro is offline   Reply With Quote
Old 06-30-2016, 08:45 AM   #14
Commercial Member
Hankook Radial RA08 195R14C D/
is actually a "commercial" tire designed to European or Asian standards (full Metric). The "C" indicates Commercial.
It is Load Range D
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 06-30-2016, 08:48 AM   #15
Commercial Member
Originally Posted by Rhoadzie View Post
I'm on the road and blew a tire today. Praise God for AAA. The spare does not match the other 3. First, is this a problem? I'm thinking of replacing two right now? Which two, same side or one on each side, or am I making a mistake? ST205/75 - 14, I think c rated.
By "blew today" do you mean a "Run Low Flex Failure" that looked like this?
This type of failure occurs when the tire looses significant air from cut, puncture or leaking valve. Your TPMS should have provided a warning in advance of the failure.
Old 06-30-2016, 08:55 AM   #16
Ford Idaho's Avatar
I had a tread separation last night, took half an hour from stop to start to put the spare on.
Will do some shopping today.
Load range D @ 65 PSI Akuret ST225/75R15, tire still has air but no tread.
Old 06-30-2016, 08:59 AM   #17
Bite the bullet and get 5 new LR D tires and have them balanced.
Old 06-30-2016, 09:06 AM   #18
Commercial Member
OK Tread Separation more like this
many times can be traced to MFG issue.
Be sure to get a couple of pictures and the full DOT S/N. You should ask tire dealer for "adjustment and replacement" of the failed tire for "manufacturing defect".
You should also plan on filing a complaint with NHTSA
If dealer refuses to adjust and replace the tire I would name the dealer in the complaint to NHTSA. In the complaint tell them the tire still held air and the failure was a tread separation and that you have pictures available if they want them. If they are interested they will ask for pictures later on.
NHTSA will send you an email with a complaint #. I would forward that number to dealer and CEO of RV company too.
It would be good for you to post the DOT S/N here so we can identify the specific plant where the tire was made.
FYI many times Trd Sep can be discovered well before the tire comes apart if a close inspection is done.
Old 06-30-2016, 09:09 AM   #19
Ford Idaho's Avatar
I am not even sure if a local tire shop here will have ST's in stock.
Old 06-30-2016, 09:15 AM   #20
Ford Idaho's Avatar
but without break in body
I can and will but I need to be quiet a bit longer....
Dealer stopped selling FR units last year so I doubt I get much there.
tire
