Old 06-30-2016, 10:55 AM   #21
Ford Idaho's Avatar
As per request.
Old 06-30-2016, 11:24 AM   #22
Commercial Member
Originally Posted by Ford Idaho View Post
Yep classic belt separation. RE Dealer. I would contact FR and ask where to go for tire replacement. Be sure to check out my blog on tire inspection. You need to check the others too. Even if you are planning on replacing them.
SHANDONG WANSHINE TIRE CO., LTD.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 06-30-2016, 11:46 AM   #23
AdamC's Avatar
Lionshead Bearcat Rim Max load 1900 lbs
Stupid question here. I would love to upgrade to Load Range D's on my trailer but my rims are only rated up to 1900 lbs. Is it safe to put D's on those rims even though the load rating is higher on the tires? I would assume as long as I don't go over the original GVWR I would be good.
2015 Surveyor 245BHS
2014 GMC Sierra 1500
AdamC is offline   Reply With Quote
Old 06-30-2016, 01:34 PM   #24
Commercial Member
Yes you should not exceed either GVWR or GAWR. You need to confirm this by visiting a truck scale.
Moving up to a tire with higher Load Range would not allow you to carry more load on the wheels, axles or in the RV but would allow you to run higher than 50 psi which can lower the "Interply Shear" that is the internal force trying to tear your tire apart.
Old 06-30-2016, 07:08 PM   #25
Ford Idaho's Avatar
Packed up and drove to Discount tire and bought 4 Carlisle ST225 /75 D15 113N D1 BSW which they had in stock.
Tire Details - Discount Tire Direct
No wish to wait on FR or the dealer I shall file with DOT ASAP.
tire
