Old 03-05-2012, 06:38 PM   #1
maggiek's Avatar
tire/brake temps
Just got a nice new laser temp reader to replace my not so sensitive fingers to test tire and brake/bearing temps. Now that I can put a figure to the heat what should I expect to see after an hour or two at 60 mph? The TT is a Rockwood Mini-Lite 2304 with 205/14's load rating C @ 50 PSI mounted on aluminum rims and the TV is a RAM with 275/20's inflated to 35 PSI.
Steve & Millie
Maggie
2011 RAM 1500 Quad Cab 2wd Hemi 3:55 gear
Rockwood Ultra-Lite 2604WS
maggiek is offline   Reply With Quote
Old 03-05-2012, 07:39 PM   #2
I spoke to a factory Rep a few years ago because I was having problems with a axle and wheel bearings by AL-CO, the Rep told me that it is normal for wheel berings to heat up to 180 degrees.
I spoke to another person about bearing grease and I was told to change the grease from the factory and use ATV heavy duty grease, it is 100% water proof and a better lubricant.
Old 03-06-2012, 10:36 AM   #3
lindy's Avatar
My temps on hubs run around 120 or so, but bear in mind that if one side of the camper is in the sun the whole time you're driving, the temps will be higher on that side then on the other side, also one side might be higher if the fridge is right over the axle on that side due to the higher weights.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 03-06-2012, 11:39 AM   #4
Wanna Be Camper
SaskCampers's Avatar
They should all be close to the same temp with the ones on the side in the sun a bit higher. Hub temps should all be close to the same. Also you truck tires should all be close to the same temps. The exact temps will vary depending on ambient temp and time of day and amount of sun due to the road heating up as the day goes on.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 03-07-2012, 03:11 PM   #5
maggiek's Avatar
Thanks to all those that replied to our query. My old fingers are happier already and I don't have to justify the heat sensor purchase. Again thanks.
Steve & Millie
Maggie
brakes
