Old 07-16-2011, 11:50 AM   #11
Fire Instructor's Avatar
Originally Posted by acadianbob View Post
Try this tire.
Kumho Radial 857
It is D rated and also rated for 99 mph.
You would need to do the 195 size to get the same rolling circumference (it is aspect ratio 82 instead of 75). But your overall load rating will still be up and you won't have to worry about the occasional 70 mph; at least from the tires . . .
I couldn't find a speed rating on the Kumho, just the "D" load rating, so if the 99MPH that you state is accurate, that's GREAT for me, as I don't exceed 70 MPH when towing.
Not sure what you mean regarding the different "aspect ratio", but if staying with the 205 raises me slightly, then that would be a good thing. My Reese drop hitch is on the bottom setting, and is still about an inch too high.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 07-17-2011, 10:04 AM   #12
acadianbob's Avatar
KUMHO Radial 857 tires feature blackwall styling and are available in Q-speed rated 82-series
This is from the Tire Rack site. Q speed rating is 99 mph.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 07-17-2011, 10:10 AM   #13
acadianbob's Avatar
Aspect ratio is the ratio of the sidewall height to tread width. Your 205/75 means the sidewall is 75% as high as the tread is wide. So, the Kumho is a slightly taller tire for the same 205 size (It is 82%; e.g. 205/82R14). That means a larger diameter for the same tread width. I have only 2" between my tires on my Surveyor. So, I would need to do the 195 size Kumho to get the same diameter tire. The larger 205 would not fit on my trailer. You need to see how much clearance you have between your tires to see if the 205s would fit. The good news is, the D rated 195 Kumho still has quite a bit more load capacity than your C rated 205s. Look at the specs for the 205/75 (your current tire) and the Kumho. Look at diameter and revs/mile.
Old 07-17-2011, 10:23 AM   #14
acadianbob's Avatar
I'm switching from 205/75R14 Marathons to the Kumho next spring. The Marathons have been flawless in performance but the advantage in speed rating and load capacity with the Kumho is too much to pass up. My Marathons will be 5 years old and have about 25,000 miles on them; time to retire them.
Old 07-17-2011, 10:01 PM   #15
Now I'm hearing from others (I posted my original question on the other forum, as well) that my factory rims may not be capable of receiving 65psi.... They are rated for 1870# mximum, but I can't find anything on them that gives a tire rating or a max psi.
Fire Instructor
Old 07-17-2011, 10:20 PM   #16
Herk7769's Avatar
Originally Posted by Fire Instructor View Post
Now I'm hearing from others (I posted my original question on the other forum, as well) that my factory rims may not be capable of receiving 65psi.... They are rated for 1870# maximum, but I can't find anything on them that gives a tire rating or a max psi.
On my steel rims they were stamped on the inside of the rim. Look at your spare (if you have one) since the brake drum won't be in the way.
My steel rims were stamped 50 PSI max, but my tire dealer said that if I upgraded the stems to a metal 100 psi stem I could go to 65 PSI and a D rated tire without worry. I run my D rated Marathons at 55 PSI as that gives me the allowable load carrying capability I wanted (assuring full tread contact) and the extra plies for strength; without an overly hard tire (IMO it was bouncing too much at 60 PSI).
HAM CALLSIGN - KC3FFW
Old 07-17-2011, 10:23 PM   #17
wmtire's Avatar
Good info from Acadianbob. I am going to copy some info I posted in another trailer forum that Chap and I both frequent from 2007, that explained the differences between metric sized tires and Euro metric sized tires and expounds a little more on it.
I don't know if I ever explained the differences between sizing systems of the metric sized tires and the Euro-metric tires before. If I did, then please ignore all this boring stuff below:
OK, the Goodyear Marathons that come on our trailers are sized in what's called simply enough "metric" tire sizing. Tires can be "P" metric , "LT" metric, or "ST" metric (which the marathons are). The P, LT, or ST designate the type of tire use, but the numbers behind that designation mean the same.
Just using the 14 inch tires for example, our trailer tires are ST215/75R14.
This means this tire is a "Special Trailer" (ST) use tire. It is 215 millimeters wide when loaded at it's normal carrying capacity (this is the space between the bulging parts of the sidewall, and not the actual tread width), the sidewall is 75 percent as tall as the tire is wide when at it's normal carrying capacity. It's a Radial (R) constructed tire and it fits a 14 inch rim.
These ST tires can come in 4, 6, or more plies, which will be designated by a Load Range letter of B, C, or higher. This Load range letter won't be in the sizing, but somewhere else on the tire.
Ok, now the tires that many of us are trying on our trailers are sized in what's called Euro-metric sizing or Euro tires as I call them. This sizing system is a little different.
Most everyone is trying an Euro-sized tire that is 195/R14C
The 195 means the tire is 195 millimeters wide.
Now note, that there isn't an aspect ratio number, which was 75 in our tire above. Euro-sized tires of this type don't put the number in their sizing. If they did, it would be an 82. This means our Euro tire is actually a 195/82R14C if we tried to make it come out to the same metric numbering system as our 215/75R14 tire above. Because this tire is 82 percent as tall as it is wide, it gives it more sidewall to stand up to the heavier loads.
It's a Radial (R) constructed tire and goes on a 14 inch rim.
Now to the C after the rim size. It's easy to confuse this for a Load Range letter, which it is not. In our Euro-sized tire, this C means it is a commercial rated tire used in heavy hauling applications. It would be similar to our "LT" or "ST" designation used above. It's just at the back of the size instead of the front
These Euro Tires will also have a Load Range designation letter located somewhere else on the tire. These tires will likely have a C, D, or higher. Most everyone is using a D (8 ply) rated tire.
Now that we know the difference in the tire sizing used for the tires, we can also understand why our metric ST215/75R14 is practically the same height as the Euro-metric 195/{82}R14C tire..........and works easily as a replacement. 75 percent of 215... is close to 82 percent of 195.
One more thing is these Euro tires are kind of a cross. They are designed not only for LT applications, but ST too. It says so even on Kumho's webpage.
http://www.kumhotireusa.com/Tire.asp...5de416c&cat=39
2011 Flagstaff 831 RLBSS
Never Apologize! Never Explain!
Sorry, thatís my motto.
Old 07-17-2011, 11:03 PM   #18
Between AcadianBob, Lou, and now wmtire, I'm now begining to understand this!!!!
Thank you, Gentlemen!!!!
Fire Instructor
Old 07-18-2011, 07:19 AM   #19
MtnGuy's Avatar
I had asked Bobby to take a look at the thread to see what he thought, and as usual he came through.
Thanks, Bobby.
Old 07-18-2011, 09:36 PM   #20
I have a pair of the 857 Kumho's 185r14 on my camper,just installed them Saturday, took the trailer for a drag Sunday afternoon, 88į out side, nice and sunny.
the ride was more to see how the tires acted to various vehicle inputs, swerving, and to check clearances of suspension movement. these tires are 1.6" taller than the 175/85R13's they replaced ( 25.6" vs 24" )
they did well, there seems to be adequate room for movement in all but the worst road bed situations.
when I got home, total trip mileage was probably 11 miles. I felt the TV tires, just to see and compare the heat build up in the trailer tires. the trailer tires were quite a bit warmer, almost uncomfortable to the touch. should I have any concerns with this ?
tire pressure was 64psi before I started ( electronic digital tire gauge )
I suppose I should dig out the IR temp gun and do this a little more scientific like.
Kevin
'12 Flagstaff Classic 625D
'97 Toyota 4Runner
Blkvoodoo is offline   Reply With Quote
led pad
