Old 08-05-2012, 02:31 PM   #31
Buy Goodyear Marathons and at least keep the majority of the money in the US of A.
Old 08-23-2012, 10:23 AM   #32
Glad I read the thread, It had been my understanding that D rated tires are only rated for 65 miles per hour at 65 psi?
whj77372 is offline   Reply With Quote
Old 08-23-2012, 11:33 AM   #33
wyo700's Avatar
Who else has had the trail America tires? I have about 1800 miles on mine and they are wearing fast. They are wearing even but fast. They are on my toy hauler and have never overloaded it. They are Load range C tire and I always keep them right at max pressure of 50 psi. I do have two fresh water tanks that equal 106 gallons and they are right over the axles and then put a 600 pound quad over that sometimes. I wouldn't think that would be an issue but I haven't read much good about these tires. I will probably have to replace next year and plan on getting the Goodyear marathons in a load range D with metal valve stems hopefully that will fix it.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 02-08-2013, 01:03 AM   #34
Trailamerica Tires
Reviving this old thread again. I have the Trailamerica tires 205/75/15 on our 2010 Wildwood and they are pretty much used up. the sidewalls are showing signs of bulging and the tread is getting thin. Thought I would look here and see what people are running.
Looks like Marathons or Kumhos or Maxxis.
Might come down to price and availlability but it needs to happen soon!
2004 F150 4.6 Griffin tuned
2010 Wildwood 24FBS
johnleann is offline   Reply With Quote
Old 02-08-2013, 08:26 AM   #35
Maxxis Tires
I had a set of the Maxxis tires on in May of last year. Since then we have been from Texas to Vancouver, Texas to the East Coast down to Florida and several shorter trips. A little over 15,000 miles. We are leaving next week on a roughly 5,000 mile trip to Southern Calif. The tire look great and do not show significant wear. No problems of any kind. They are expensive, but in my opinion worth the cost.
JPSPete20 is offline   Reply With Quote
Old 02-08-2013, 08:33 AM   #36
Herk7769's Avatar
This is totally true. IF you require 65 PSI to support your load and the maximum pressure on the tire is 65 PSI, your maximum speed is 65 MPH.
IF - the load can be supported at 55 PSI with that D rated tire, you can over pressure (up to 10 PSI) Marathons (and I assume others) to increase the speed limit up to an additional 10 mph.
HAM CALLSIGN - KC3FFW
Old 02-08-2013, 09:14 AM   #37
I didn't find them "expensive" considering what I was getting for the money.
Yes, there are cheaper tires out there, but they are CHEAPER tires!
As for the OP, even if he is always going 70 mph, the Maxxis should be fine.
bakken is offline   Reply With Quote
Old 05-21-2018, 01:51 PM   #38
Hi ok I have a 2017 Georgetown motor home 30x3 it has 245/70R19.5G.
I am going out West this spring ( east to west ) for about 3 months I was thinking of changing the front tires to the next size up? The tire size iam
Thinking about is 265/70R19.5 ? If you go to www.tacomaworld.com/tirecalc?tires. And it will calculate the difference. So what is your opinion thank you
1964chevelle is offline   Reply With Quote
Old 06-05-2018, 05:22 AM   #39
Bought a new Mini-lite 2507 last summer. Replaced the Chinese "may pops" this spring with Goodyear Endurance tt tires. Just came back from 4000 southern swing. Horrible roads in NY, NJ and PA. No problems road very well, solid no sway. Money well spent.
Aucoot is offline   Reply With Quote
led pad
