03-23-2016, 12:02 PM
#21
I tried to put Goodyear G rated on my Crusader and there was only about 1/2 inch to 3/4 clearance between the back sidewall of the tire and the slide rod that operates the slide. The dealer proved to me if I starting losing air pressure the sidewall of the tire would contact the slide rod and shred the inner sidewall of the tire. The only thing I could of done is find a rim with offset the would work.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
03-23-2016, 12:24 PM
#22
AS Davidg mentioned the Constancy tire seems to be a cheap China tire. I have them on my Sabre and am having Maxxis installed tomorrow. I ordered them through Discount tire and it took a week to get them in the store. Cost about $176 per mounted with Discounts tire replacement warranty.
03-23-2016, 01:11 PM
#23
JR, that's a good price. I do not have a Discount Tire store in my area, and the closest Maxxis dealer is over 150 miles away, but I'm still planning on having them installed. From Amazon, they are $159 per tire no shipping cost. Then probably $20 - $25 per tire to have them mounted and balanced. If I could get them installed for what you paid, I would have it done tomorrow.
I will register them with Maxxis, but I'm sure there will be zero warranty in my case, which does bug me a little.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
03-23-2016, 01:26 PM
#24
A Trailer Tire Poster
03-23-2016, 01:40 PM
#25
Always Learning
Originally Posted by Davidg
JR, that's a good price. I do not have a Discount Tire store in my area, and the closest Maxxis dealer is over 150 miles away, but I'm still planning on having them installed. From Amazon, they are $159 per tire no shipping cost. Then probably $20 - $25 per tire to have them mounted and balanced..
I ordered my Maxxis from discounttiredirect.com and had them shipped directly to me (no shipping cost). The local Merchant tire place mounted them for me for nothing more than tipping the garage guys for the first 3. For the second 2, the manager was around and I had to pay.
I didn't have them balanced. They talked me out of it - against my better good sense.
03-23-2016, 02:19 PM
#26
Originally Posted by Airdale
Airdale, How do you interpret this from Maxxis website? Especially the part about the warranty only being valid if they were oem tires on the trailer. Just curious.
Eligibility
You are eligible for the benefits of this warranty (the “Limited Warranty”) only if you are the original owner and consumer of new Maxxis trailer tires, such tires bear the original Department of Transportation(DOT)-prescribed tire identification numbers, "and" such tires are on the trailer upon which they were originally installed according to the trailer manufacturer’s or Maxxis’ recommendations.
03-23-2016, 06:15 PM
#27
Eligibility
Consumer is the same thing as purchaser. Owner, is owner of new unused Maxxis tires.
When you register your tires send maxxis an email requesting their warranty information. You are going to use them to replace like sized tires, aren't you?
03-23-2016, 07:17 PM
#28
Yes, the trailer came with 235/80R16, which is the size Maxxis tire I'm looking at.
03-23-2016, 07:54 PM
#29
I checked their website. They are actually a couple bucks less than Amazon. They also have a $20 per tire "insurance" plan. I read through the details. They sure make it sound good, and for ST tires, that may not be a bad deal, as long as they don't require the old tire back...shipping to be at the owners expense of course.
