Old 07-26-2013, 02:36 PM   #1
dcheatwood's Avatar
Tire diameter
I'm going to repalce my original Trail Express tires at some point. They are 225 75R 15C. I want to go to D-range tires. The problem is that on my unit, I only have 2 3/4 inches of space between the tires now. The Rockwood 8282WS has torsion axels.
My current C-range tires are 26.5" diameter. I can't find D-range tires less than about 27.5" diameter. That would close the distance between the tires even more. I guess my question is this. How close can I mount my tires and still not worry about them touching while towing. I'm surprised that they came so close. Any input appreciated.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 07-26-2013, 02:45 PM   #2
Fulltime family RVer
I do NOT have torsion axles, but I can say that my tires are about an inch and a quarter apart from each other.
ependydad is online now   Reply With Quote
Old 07-26-2013, 02:46 PM   #3
AquaMan's Avatar
Where did you get your measurements from? By measuring or from the manufacturer? Most tires that size I'm finding are around 28.3". I would think as long as you put same size back on, you should be fine, regardless whether they are C or D rated.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 07-26-2013, 02:49 PM   #4
wmtire's Avatar
I'm not sure I understand your question here. Are you replacing the tires with the same size as your original tires?
If so, then Load Range/Ply Rating doesn't usually make any difference in the actual diameter.
Although there are some small diameter differences between tire brands/models, depending on how they measure the tire....it's usually fairly small.
What can affect the actual diameter, is wear. Are you measuring the diameter of the tires that you have currently on the trailer.........that will have less tread now since they are used......as compared to a new tire specifications on a chart?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 07-26-2013, 02:58 PM   #5
fonzie's Avatar
I replaced mine with GoodYear Marathon and either load range c or d will fit, same radius at 28.3 inches ( same as Trail Express)
See link below. Go to tire selector and then marathon to see chart.
Goodyear RV Tires
Fonzie
Old 07-26-2013, 09:23 PM   #6
dcheatwood's Avatar
E. Do you have torsion axles? Any rubbing?
Old 07-26-2013, 09:25 PM   #7
dcheatwood's Avatar
Disregard. I see noe. Thx.
Old 07-26-2013, 09:28 PM   #8
dcheatwood's Avatar
May have to sneak out with tail tucked. I measured from ground up. Didn't consider squish factor. Mine measured 26.5" from ground. Will remeasure horizontal tomorrow. What a duh! Moment.
Old 07-26-2013, 09:38 PM   #9
If you insist on measuring, measure the circumference of the spare if it is the same size and divide that measurement by pi (3.1416) or jack up a wheel and measure it's circumference.
tire
