09-24-2018, 09:30 AM
Tire goes flat when loaded, holds air otherwise
Thursday night, headed out when my TPMS starts yelling at me. Shows 71 PSI and 23 miles ago it was at 80. by the time i pull of the highway, it was down to 65.
Changed tire at a nice gas station and since it was also a truck stop, had high pressure air available so I topped off spare and added air to the tire I had taken off.
so by sunday, no air had leaked from the "flat" tire. and Autotire called and said there was nothing wrong with the tire. Any ideas?
also, the tires are new Carlise HDs, just got them this May, have about 5k miles on them. Always run at 80 PSI on a 9k 5th wheel
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
09-24-2018, 09:32 AM
Denver To Yuma In 90 Days
Possibly a bad valve stem or microscopic cracks in the wheel?
09-24-2018, 09:39 AM
Recently new!
Agree, maybe the valve seal did not seal all the way after your last inflation/pressure check? Put it back on, drive it around a bit when it is easy to do, see how it holds up.
May have even been a rim seal leak that resealed itself...or as JohnD10 says, rim issues that show up under a load?
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
09-24-2018, 09:59 AM
I have also seen valve cores stick, or get bent by a person checking the air pressure.
This can allow air to bleed out, then sometimes the core closes up a second time or when you check pressure again.
We once had one of the oil/change lube places near us, that had an air chuck that was messing up the cores. After we replaced a lot of them, we were able to find out the common denominator, and I went down a looked at their air chuck, to see the problem. They replaced it and problem was solved.
2011 Flagstaff 831 RLBSS
since i have the non flow through TPMS sensors, i haven't added/ needed air since June or so.
09-24-2018, 10:57 AM
Check your valve stems I have had problems with the rubber base ones cracking. I don't notice it until I go to put air in em. They hold air when stationary. I have a TireTraker TPMS system and I think the movement of the sensors while driving is causing the problem. Just got back from a nightmare trip where I had 3 blowouts. I ordered all metal valve stems yesterday.
2021 Alpine 3790FK
2021 F-350 SD XLT PS 6.7 Dually Longbed 4wd Crew Cab
09-24-2018, 11:01 AM
Who Dares, Wins
We had a small defect in a rim (turned out to be two later this season) that would leak air when the rim warned up. Once it cooled the hole sealed up and held air.
2015 Chevy HD D-Max
2022 Impression 315MB
09-24-2018, 11:13 AM
We had a DIC alert of a low tire on TV. Dropped trailer and went to "Michelin Tire "as that is what the tires are! They removed the tire and checked it??,said Not our problem! We went to Chevrolet Dealer and they replaced the valve stem N/C and we were on our way! Sorry Tire Dealer! Youroo! !
09-24-2018, 11:19 AM
Another vote for the valve stem being the problem. I had a tire go flat in my drive way hours after checking the pressure in all the tires on my TT. I removed the tire, took it to my local friendly tire shop where they over inflated it to check for leaks and found nothing. The tire guy had a little tool in his shirt pocket that he jabbed at the valve core stem and repeatedly sprayed soapy water on the valve stem. After one of the jabs the soapy water bubbled like a bubble bath. He says the core just would not seat correctly all the time. All new heavy duty metal stems on all tires, including the spare. Not a problem since.
09-24-2018, 12:32 PM
Even so............It is only flat on the bottom, the rest sounds fine to me.
Sorry, I just could not resist...........
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
09-24-2018, 12:46 PM
I experienced a leak in the wheel itself. You might want to check this out.
09-24-2018, 01:22 PM
Air pressure does not change with load
If your tire is inflated to 80 psi as a spare tire not touching the road it will be 80 psi under load and not too surprisingly the pressure on the road surface is 80 psi whether loaded or unloaded. What changes is the amount of tire making contact with the road and the amount of surface contact will be your weight divided by the inflation pressure in square inches.
I had a tire leaking air occasionally and it was a loose valve core. Tightened it up and all is OK.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2200i Generator, 300 Watts Solar
Ham Callsign KD7UM
09-24-2018, 01:53 PM
2012 Solera
My father - a mechanic in the middle of the last century who taught high school auto mechanics in the 1960s - said “always check a valve for leaks - spit on it - before putting the valve cap on”. That advice has served me well. Tire valves often don’t seat quite right. A quick press and release usually fixes ( no bubbling spit).
JLeising
2012 Solera "S"
Calif SF Bay Area
09-24-2018, 02:13 PM
Let us know what you find, I'd be curious to know.
(valve stem, rim, cold vs hot tire, etc) Thanks!
09-24-2018, 02:17 PM
sidewall pinhole...
I had a tire with a tiny pinhole leak in the sidewall... depended on where the hole in the sidewall was located when I parked, it then leaked either a lot, or very little. By very little I mean a # per 2-3 days, or a lot... like several #s overnight.
Tough to find that hole...
2014 Shamrock 183
09-24-2018, 02:22 PM
I think the tpms sensor could gotten loose allowing a small leak.
09-24-2018, 02:54 PM
I had the same problem. Installed non flow through TPMS on rubber valve stems. Tires held set psi for month. Took a trip and one started loosing air not alot but enough to be concerned.
Long story short. When the tire was rotating at speed the weight of the TPMS would bend the rubber valve stem (centrifical force), air would leak around the stem hole in the wheel and stem. Took awhile to find this.
Most likely why the TPMS instructions suggested using metal valve stems. I have metal stems now.
John And Mary
2016 Venom 3311TQ
2013 CHEVROLET 2500 6.6 DURAMAX
Nights Camped 2012 (7) 2013 (33) 2014 (27) 2015 (34) 2016 (27) 2017 (32) 2018 (34) 2019 (35) 2020 (20) 2021 (5)
09-24-2018, 05:59 PM
My guess is you have a small nail in your tire. The load is flexing the tire to allow for leakage.
09-24-2018, 07:29 PM
Pump it to 80 psi, submerge it in a tub of water, or something to get parts of it under water. Like a splash pool a foot deep. It'll bubble.
09-24-2018, 07:43 PM
Keep us updated on what you discover
Tim & Vanessa Jones
2017 F-250 6.2
2019 Flagstaff Microlite BRDS25
