Old 07-29-2016, 08:17 PM   #1
Tire inflation question
We just took delivery of our new FR Wildcat 31SAX a week ago. This is our 3rd rig but first 5th wheel.
The tires are ST225 75R15. (I think we should upgrade to 16s, but that's another subject...)
The tire walls indicate they should be inflated to 80 PSI (cold) but the rig itself says the tires should be inflated to 65 PSI.
Why the 15 PSI difference? Honestly it feels like the tires aren't at all balanced, but I'm starting to think they're underinflated (IMHO) and it's causing the rig to feel bouncier.
What gives?
abi2001 is offline   Reply With Quote
Old 07-29-2016, 08:25 PM   #2
Left Coast
Every time I try to run 80 lbs everything inside moves around a lot....so I stick with 65.......same size tire as you, only have 2 d rated and 2 e rated....( long story)
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
bob caldwell is online now   Reply With Quote
Old 07-29-2016, 09:05 PM   #3
Interesting... Thank you for the insight!
Old 07-29-2016, 09:19 PM   #4
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
Sidewall says 80psi, I run 80psi. Just me.
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
Old 07-29-2016, 09:20 PM   #5
That's what I figured... But I just don't understand why the rig says something completely different.
Old 07-29-2016, 09:23 PM   #6
Left Coast
Have the tires on yours been changed to a higher load rating....believe C is what they come with....65lb tire
Sent from my XT1585 using Tapatalk
Old 07-29-2016, 09:26 PM   #7
Hmmm... Not sure. That's worth looking in to. We haven't changed them but I don't know if the dealership did or something. Thanks for the tip!
Old 07-29-2016, 09:29 PM   #8
Left Coast
Load rating will be on sidewall, along with a load rating for the 80lb tire at 80lbs....compare that to the sticker....
Old 07-29-2016, 09:30 PM   #9
Left Coast
To dark here now to see what mine say.....
Old 07-29-2016, 09:50 PM   #10
We just stopped to look. The specs/sticker on the rig indicate these are indeed the size and load that came with the rig. :/
tire
