Old 03-30-2014, 09:50 AM   #21
f5moab's Avatar
I had the same problem with the sensors dropping signals, but in my case, it was not due to the spring holding the sensor. I have a two tire trailer, and had four sensors, so I even swapped out the non-used sensors, batteries, etc., and after a few hours it would drop.
Maybe I needed a booster, but most other systems I have looked at don't require it for a pickup truck running a popup. And even standing next to the trailer tire, with the unit, fully charged, in my hand, it would lose a sensor signal.
So, somewhere in Montana, the system, with the sensors went into a dumpster. I kept the window mount bracket, it worked ok.
Hopefully, the TST system will work better....
f5moab is offline   Reply With Quote
Old 03-30-2014, 10:07 AM   #22
Witch Doctor's Avatar
Originally Posted by f5moab View Post
I would like the flow-through sensors; however, I'm not sure they will fit. The standard sensor, which appears to be the same ones used with the Tireminder system, just fit inside the wheel opening where the valves are.
With what I see you might have a problem with just the screw on type but the Blow Through has a longer shaft and should fit well. The extra weight which is twice the weight of the screw on wouldn't bother you at all. IF not you can always send them back, but I think yours is an ideal stem rubber or metal.....
Coachmen M/H
Concord
2018 / 300 DSC
tire
