Old 05-03-2014, 10:09 PM   #1
Kash76's Avatar
Tire pressure
I just want to make sure that I am doing the right thing here. Please look at these two pictures
The bottom picture has nothing to do with the air pressure correct? So, just go 50 PSI cold (no sun or recent driving on the tire) correct?
Thanks!
2013 Palomino SolAire 317BHSK w/Eclipse package using a ProPride 3P Hitch
2013 Ford F-150 Ruby Red SuperCrew 4x4 EcoBoost w/Max Tow, e-lock, Michelin LTX M/S2 tires, & Air Lift 5000 Ultimate w/Load Lifter
Campers: Me, DW, DD, DS
Nights camped: 2015 (4) as of 5/25 2014 (44) 2013 (26)
ProPride Review
Kash76 is offline   Reply With Quote
Old 05-03-2014, 10:13 PM   #2
Crusadernoob's Avatar
Correct!
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!
Nights camped in 2014 37
Nights camped in 2015 40
Nights camped in 2016 39
nights camped in 2017 38
Crusadernoob is offline   Reply With Quote
Old 05-03-2014, 10:22 PM   #3
Kash76's Avatar
Thanks. Any reason to go shy of 50?
ProPride Review
Old 05-03-2014, 10:26 PM   #4
Brother Les's Avatar
While you are checking your tires for 50 psi, cold.... also check your lug nuts are the right torque.
Brother Les
Old 05-03-2014, 10:34 PM   #5
No reason to go less than max pressure when cold, usually all of our trailers are loaded and very close to max load, go with max pressure when cold and you won't have as many problems, under inflated tires build more heat and will cause problems.
Old 05-03-2014, 10:40 PM   #6
The bottom picture is a warning to the installer about going above 40# to seat the tire on the rim. If you watch them, there is usually a loud pop when the tire seats to the rim. I would imagine they are worried that pressure above 40 might fracture the rim when it seats. JMO.
Old 05-03-2014, 10:42 PM   #7
Kash76's Avatar
Thank you all for the information and tips
Sent from my Galaxy Note 3 on Tapatalk
ProPride Review
pressure, tire
