Old 10-22-2013, 08:32 AM   #51
Fulltime family RVer
Originally Posted by BigBaron View Post
TOWTA
The One With The Authority - aka Mrs. OldCoot.
ependydad is online now   Reply With Quote
Old 11-06-2013, 10:32 AM   #52
I just ordered the 507 with 10 flow through valves. I'm hoping that they will go on the rear dually tires without too much of a problem. I guess I'll have to wait until they arrive. It would be real nice if I was handy like OC in building different things but I'm not so I will have to find something to hold the sensors in the off season.
Pipeman is offline   Reply With Quote
Old 11-06-2013, 10:48 AM   #53
I just received the Tire Tracker system. I am thinking about placing a transmitter on my truck tire spare if there is room. The tire is mounted under the bed, valve up so I need to take the jack apart and lower it to check the air. Sort of a pain. Not sure if the TX will worked all tucked up under the bed, but they are cheap enough to give a try or try one that came with my set up. I think they are a great investment. had 3 blow outs on my previous TT totaling over 3K in damage. These systems wont help in a blow out but a low tire that shreds does plenty of damage.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 11-06-2013, 10:58 AM   #54
Displaced2's Avatar
Just picked my unit up. Had 507 installed. Five miles down road passenger inside reads 0 air and driver inside not reading. Back at service center to be corrected.
Displaced2 is offline   Reply With Quote
Old 11-06-2013, 11:14 AM   #55
Never a dull moment
Old 11-06-2013, 12:16 PM   #56
Dave_Monica's Avatar
I've also put TST 507 flow-through sensors on our camper. I hope that you're aware that these sensors need a metal valve stem due to their heavier weight. Regular rubber valve stems may fail according to the TST manual.
Dave
Old 11-06-2013, 12:24 PM   #57
Lowes or HD have plastic boxes with partitions. Mark your sensors with paint to designate their positions and mark the plastic box compartments accordingly and stow them in it. Shop Flambeau Small Tool Storage Containers at Lowes.com
Old 11-06-2013, 01:21 PM   #58
The TST 507 kit comes with stickies (decals) to mark the sensor and the corresponding wheel.
Dave
Old 11-06-2013, 01:26 PM   #59
Dave
And they last about as long as it takes to put them on when you hit rain and you need 2 sets, 1 for the sensors and 1 for the box
Old 11-06-2013, 01:47 PM   #60
Displaced2's Avatar
Replaced stems with wire braid and secured inner stems to wheel cover.
Drove home, 100 miles, working well. Ned to discover sweet spot to mount.
pressure, tire
