Old 11-06-2013, 06:16 PM   #61
To add metal vale stems would require a break down of all eight tires on truck and trailer, is this really necessary?
gee whiz 11/5/2013
Gee Whiz is offline   Reply With Quote
Old 11-06-2013, 06:19 PM   #62
Originally Posted by Gee Whiz View Post
To add metal vale stems would require a break down of all eight tires on truck and trailer, is this really necessary? gee whiz 11/5/2013
Yes
Old 11-06-2013, 06:39 PM   #63
Ford Idaho's Avatar
Depending on how long the stems are you could get away with just letting the air out and squeeze the tire down enough to remove the old and install the new without removing the tire.
Old 11-06-2013, 06:45 PM   #64
Commercial Member
Even though I have a tire mounting machine in my garage when I changed from standard valves to TPMS valves that is what I did on my 6 tires.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 11-06-2013, 06:49 PM   #65
Commercial Member
Originally Posted by Displaced2 View Post
Replaced stems with wire braid and secured inner stems to wheel cover.
Drove home, 100 miles, working well. Ned to discover sweet spot to mount.
My setup for 17,435 miles Zero problems.
Old 11-06-2013, 06:57 PM   #66
Ford Idaho's Avatar
A Meritor inflation system for pickups would be nice if they could be retrofitted and affordable.
Old 11-10-2013, 07:35 PM   #67
My question is, does the tps sytem work or a waste of money? I tow a 38 ft 5th wheel, will the system monitor from inside my truck back to the trailer tires. 2007 Chev. 2500 HD crew cab. will I need some kind od booster signal?
Old 11-10-2013, 08:01 PM   #68
Dave_Monica's Avatar
If you order from TST, they will be recommending that you buy the optional repeater for any camper longer than 30 feet.
Dave
Old 11-10-2013, 08:08 PM   #69
I have a 39ft 5er with a Chevy 3500 long-bed and the TST 507 system works great for me with no repeater. Your results may be different. Try it. Add the repeater if you need it.
Old 11-10-2013, 08:20 PM   #70
camper1999's Avatar
X2
35 footer no repeater works great
2011 GMC 2500HD Diesel
pressure, tire
