Old 06-05-2015, 04:19 PM   #1
Angry tire pressure monitoring system
Wow what a week! We just returned home from our shake down trip to prepare for our Alaska trip in three weeks. Everything went perfect until we started home. We had been traveling about twenty minutes when my tire pressure monitor ALARMED. I have brand new Cooper tires and had just checked them before we left the campground and everything was ok. I pulled off the road and checked anyhow and all was well. This is the third false alarm. The system is Tire Minder and it is time to replace it. Does anyone have experience with a different system?
dwebster is offline   Reply With Quote
Old 06-05-2015, 04:28 PM   #2
TST is what I have and have had no issues. Great customer service.
Filthy Beast is offline   Reply With Quote
Old 06-05-2015, 05:20 PM   #3
f5moab's Avatar
Had a short experience with Tire Minder, but literally threw the display and sensors in the garbage somewhere in Montana. Only word I can use on this forum is Junk; all others would get me banned.
Switched to TST and never had a problem in two years. Changed the sensors' batteries this spring and they registered on the display in about a minute.
f5moab is offline   Reply With Quote
Old 06-05-2015, 05:36 PM   #4
acadianbob's Avatar
TST has worked very well for me. Really like it.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 06-05-2015, 07:41 PM   #5
What was the alarm? Low pressure, high pressure, temperature?
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-05-2015, 07:53 PM   #6
Alarm
The pressure was blinking. It was showing higher than I measured
Old 06-05-2015, 07:57 PM   #7
Flybob's Avatar
Go with the TST 507 alarms are settable for low high and temp. I have had two TST monitors and never had an issue. Original one did not have user replaceable batteries in sensors. I upgraded with the last TT purchase and love them. You will need metal stems, but that is something you should do any way. Suggest you have dealer that mounts stems, balance as well with sensor attached. Many people say TT tires do not need to be balanced, but they rotate the same or higher speed as the Tv tires and no one dries with unbalanced TV tires.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-05-2015, 08:31 PM   #8
Alarm
Thanks for the info. I just put new tires on with metal stems. This is the third strike for Tire minder. It is just not a reliable system. We are leaving for Alaska on July 1, and I do not need any extra problems
Old 06-05-2015, 09:19 PM   #9
UmptySquat's Avatar
I just installed an EEZ RV Products system (10 sensors). Love it. Great support too.
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
UmptySquat is offline   Reply With Quote
Old 06-06-2015, 12:31 PM   #10
edt
tire pressure will go up as you drive and read low if you couldn't tell coalspot have fun in Alaska the temperature changes will drive a pressure pro pressure pressure system crazy
edt is offline   Reply With Quote
pressure, tire
