Old 08-31-2014, 07:04 PM   #1
Forbes's Avatar
Tire Pressure Question Again???
Know this has been kicked around the block several times and I have read several of the threads and not found an answer so here goes again.
We have a 2010 CC 36RE with a yellow sticker showing 110 pounds pressure for called tires of LT235/85R16/G, witch is what I have on the unit (Goodyear) cold inflated to 110 pounds.
Now for problem and question: All four tires are showing under inflated wear on the inside and outside edges. I have 7000 pound LCI axles with Center Point Air Ride installed by LCI with TPI monitoring system. Over the past 8 weeks I noted some information about tires while pulling after having the Center Point installed, Tire pressure according to TPI was running between 110 to 115 pounds, temperature was between 90 to 110 degrees on hottest days, hub and axle was running between 90 and 100 degrees again on hottest days (using laser temperature finder). The wear is even on all four tires and according to the tire people at shop tires are still in great shape.
My question to them and here is should I over inflate the tires to 115 to 120 pounds combat the tire wear or look else where for problem.
The tire shop could not give me a satisfactory answer as they where not sure.
Forbes is online now   Reply With Quote
Old 08-31-2014, 07:08 PM   #2
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Have you considered axle alignment the culprit and not tire pressure?
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 08-31-2014, 07:13 PM   #3
Ford Idaho's Avatar
I would not overinflate the tires for any reason.
Doing so may violate your warranty.
Old 08-31-2014, 07:14 PM   #4
Ret E-9 Anchor-clanker
donanddona's Avatar
It is said that once a tire develops a "wear pattern" it will keep that pattern through out the tire life. It is true. That said you can over inflate a tire to wear the center track down, just never never ever under inflate a tire.
donanddona is offline   Reply With Quote
Old 08-31-2014, 07:29 PM   #5
Forbes's Avatar
This was checked and done while at FROG by LCI when they installed the Center Point Air System. Good point, may have to have it rechecked.
Old 08-31-2014, 07:44 PM   #6
BamaBob's Avatar
NEVER over inflate! Tire pressure will increase as the temperature rises and you could risk a blowout. If the Rated TP is 110 Cold, keep em at 110 Cold (you will probably see them go to @ 115 @ 90-100º
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is online now   Reply With Quote
Old 09-01-2014, 10:38 AM   #7
Airdale's Avatar
Maybe you should find some good weight scales to see what your trailer weighs. You could be carrying too much weight for the tires.
Airdale
Airdale is offline   Reply With Quote
Old 09-01-2014, 10:42 AM   #8
Forbes's Avatar
Update to tire inflection on LT235/85R16/G, spent morning at tire dealer where I got my tires. He had the same tire in stock so I pulled one and checked it against my tires. I was wrong on tire wear, the new tires did not have groves on side as regular tires do, they are somewhat smooth compared to others. We measured the tire depth and check all tires for wear and they are OK and will within usage for wear. We pulled the spec up from Goodyear and 110 pounds is right for load, he also checked alignment of axles and balanced the tires to insure a smother ride.
Old 09-01-2014, 11:22 AM   #9
vinmaker's Avatar
I would not over inflate either. Not sure what is causing the problem. I think you need to get a few opinions by a couple different tire shops and weight the information.
You might just need to replace the tires.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 09-01-2014, 12:26 PM   #10
Have the same problem with my tires, asked my tire man who has done this since he was a kid he said the tire sidewalls are not stiff enough, probably too much weight on them or get stiffer sidewalls
larmman1 is offline   Reply With Quote
pressure, tire
