Old 07-07-2015, 07:40 PM   #1
Tire PSI
Truck door stickers states 35psi.
Tires are rated up to 44psi.
Will increasing the psi help with trailer sway/stability of ride?
Thank You
mfMcFroggierPod is offline   Reply With Quote
Old 07-07-2015, 07:49 PM   #2
It will help some, but the P tires will still squirm and wear faster. You need LT LR D or E tires.
Old 07-07-2015, 07:49 PM   #3
Crusadernoob's Avatar
Yes and no, you can run the max tire psi. But that is recommended for max tire load. It will help, but not as much as a higher load rating tire at a higher psi. If you get the soft, floating, not secure feeling I would up the psi.
Got more specs on what you are carrying for a load?
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
Crusadernoob is offline   Reply With Quote
Old 07-07-2015, 07:55 PM   #4
1,100#pin 5thr
Old 07-07-2015, 07:56 PM   #5
I will get the D+ at next tire change, just curious about any improvements w/higher psi. I understand my ride will get a little firmer....
Old 07-07-2015, 07:59 PM   #6
I run LR E on my truck and when not towing, just let the air down to 35# front and 30# rear and it rides just about as well as on the P tires.
Old 07-07-2015, 08:00 PM   #7
265/70R17
Old 07-07-2015, 08:01 PM   #8
What psi would you run the D's or E's at when towing?
Old 07-07-2015, 08:16 PM   #9
What is the max psi my rims are rated?
2010 GMC Sierra 1500 4x4
Old 07-07-2015, 08:29 PM   #10
B and B's Avatar
Hello,
Had a F 150 Screw Ecoboost Max Tow. Towing a pin weight 1800 lbs
1. I ran the P series tires at 44 psi, was better and less squirmy, not perfect
2. I did put E's on and ran them at 65 psi on the stock rim with rubber valve stems. Worked Great!
Brian
B and B
Old 07-07-2015, 08:32 PM   #11
I run 60# front and 65# rear towing on the LRE Goodyears.
Old 07-07-2015, 08:33 PM   #12
Sounds like E's, I can't find LT D's.
Old 07-07-2015, 08:37 PM   #13
B and B's Avatar
I prefer Michelin tires. Have never had a failure in 30 years of use! The F 150 had 20 inch wheels which limited my choices in sizes in E.
B and B
Old 07-07-2015, 08:40 PM   #14
DF5.4's Avatar
I went to E rated tires earlier this year. I ran the P rated tires at 50psi when towing and it helped. The couple of times I've towed with the new ones I ran them at 55psi. It made a huge difference in stability. I run them at 35psi when not towing and i think the truck rides better than it did with the P rated tires.
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
Nights Camped 2015-5 in TT
DF5.4 is offline   Reply With Quote
tire
