Yes and no, you can run the max tire psi. But that is recommended for max tire load. It will help, but not as much as a higher load rating tire at a higher psi. If you get the soft, floating, not secure feeling I would up the psi.
Got more specs on what you are carrying for a load?
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
