Old 08-13-2016, 10:21 AM   #1
Tire ratings and axles on 5ver
We have a 2013 Rockwood 8381 ss that we purchased used this spring.The dealer put 5 new tires on it - load rated C.
We hit a pothole on a recent trip and it destroyed the rear passenger tire.
We have tire replacement insurance that will replace at no cost.
Our tire man says he would go with 10 ply E rated tires as replacements and we need to at least match both tires on an axle. So I am also buying a second E tire (Can't afford to buy 3 right now-but will get the other 2 soon)
My question is should I place the stronger tires on the front arrears axle? Does it make a difference?
NavigatorC130A
2011 F250 Super Duty 6.2L 16-Valve EFI V8
2013 Rockwood 8281SS Revolution Pin
NavigatorC130A is offline   Reply With Quote
Old 08-13-2016, 10:34 AM   #2
SeaDog's Avatar
If your trailer is setting level when hooked up the weight difference between the front and rear axle should not be a real factor. even tho the new tires can carry more weight you need to load so as not to exceed the C rated tires that remain on the rig
Retired Navy
2016 Flagstaff 26 FKWS
Old 08-13-2016, 10:49 AM   #3
I was not. Planning an loading any heavier - just increasing the safety factor.
I was wond r in if any forces going down the road would cause more weight on either the front or rear axle,
NavigatorC130A
Old 08-13-2016, 05:47 PM   #4
When you are hooked up, if the front of the trailer is high you have more weight on the back axel, if nose down the front axle will carry more weight.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
axle, tire
