Old 04-11-2012, 07:56 PM   #21
DDC
DDC's Avatar
If you have ever seen a tire spun on a balance machine you would realize that it should be illegal to mount a tire without balancing it,it can be quite a violent action.
DDC is offline   Reply With Quote
Old 04-11-2012, 07:58 PM   #22
DDC
DDC's Avatar
My dealer balanced mine before delivery.
Old 04-11-2012, 11:14 PM   #23
Was that included? I have to bring my unit back to the dealer for a few things after this trip...I'll inquire about that just for the hell of it..
2015 Dodge 2500 Big Horn 4x4 6.4 HEMI
2015 Grand Designs Reflections 323 BHS
Reese 16K Quick Slide with Factory Rail Kit Option
kozzy is offline   Reply With Quote
Old 05-16-2012, 01:01 PM   #24
Does anyone know what type of lug wrench I need to remove one of my tires. A standard 4-way lug wrench or a standard socket won't fit the nut or inside the space on the rim?
metalaman is offline   Reply With Quote
Old 05-16-2012, 01:04 PM   #25
Don't know the size, but it will no doubt be a deep thin wall 1/2" drive socket and breaker bar/ratchet/torque wrench.
Old 05-16-2012, 03:25 PM   #26
I used an impact socket. I think it was 13/16 size. And it was tough to get in that aluminum rim. The 4 way I couldn't get in at all.
Old 05-16-2012, 04:03 PM   #27
Witch Doctor's Avatar
You should have gotten an app. that you have to call in and reg. FR pay's for 1 year roadside service assistance. they will cover the cost of repair and the tow truck to change it. It is called Coach-Net the web site is NMC home | Roadside Assistance | Independent Sales Rep | Coach-Net | RV Technical Assistance | Emergency Security Plus if you need it replaced or repaired they cover it. BUT YOU HAVE TO REGISTER......Good luck and enjoy yourself, you are covered.
Old 05-16-2012, 05:40 PM   #28
bob213's Avatar
America's Tire around here will not repair a bias ply ST tire. They will repair a radial.
bob213 is offline   Reply With Quote
Old 05-16-2012, 09:28 PM   #29
I ended up getting it repaired at a tire place. And I did some research and all said as long as the side wall is not damaged...and you use a plug/patch and not just a plug...all should be good. I did finally receive my roadside assistance package...it didn't say I needed to register though...I got the membership cards and everything.
Old 05-25-2012, 01:45 AM   #30
Too old to be too smart
SpringerPop's Avatar
I just bought four new Maxxis 13" tires for my (new to me) little Flagstaff. I also bought a TPMS. It took a week to get the sensors from Georgia (shipped ground).
I wouldn't take the tires home from the tire shop until I received the TPMS sensors to put on for proper balancing. I believe it's very important.
Proper inflation, monitoring, and balancing should all go a ways to forestalling tire problems.
Can't say I didn't try!
A proper repair is a patch on the inside of the tire in the tread area. Patching a sidewall is asking for another tire failure.
I suspect Wally-World's tire repair policy is for loss-prevention (read lawsuit) reasons. They can't be too careful, and it just costs the consumer to follow their lawyers' recommendations.
Pop
2005 Terry 250RKS, perfect for the two of us and the pups.
It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
