Old 06-17-2018, 07:31 PM   #1
member
Tire Replacement???
I searched the forum and didn't find anything regarding this situation specifically so I apologize if I'm duplicating conversations...
I had my first blow out today and am going to replace all 4 tires with Goodyear endurance. Upon my search for my OME tires, size ST 225/75 R15 load range C max psi 50, I could only find the endurance load range E with max psi 80. To get to load range D, the tire size is 205/75 R15 load range D max psi 65. (I realize there are other tire manufacturers with same tire sizes and load range but I want to buy a better set of tires).
My question is...will I be ok using the load range E tire? Will my rims handle the psi pressure? I looked on the back of my aluminum rims for any psi ratings and couldn't find any. All I could see was a max weight of 2150.
Any advice you can give me would be appreciated. My next trip out is in a week and I'm told by tire shops around here that I have to order them online and have them installed as they don't carry a lot of trailer tires.
2019 Cedar Creek Silverback 31IKS
2017 F 250 6.2 gas 4.30 8' bed
HIDE OUT is offline   Reply With Quote
Old 06-17-2018, 08:06 PM   #2
There is a huge amount of information on this subject, here. I just bought that tire in the load range E at Discount Tire and I could not be more happy. There was even another TT there, doing the same. The TT feels nice and smooth on the highway. The 15" tire was one of the reasons we selected this model from Surveyor.
Ram 2500 diesel / FR Surveyor 251rks
debit is offline   Reply With Quote
Old 06-17-2018, 08:12 PM   #3
Originally Posted by HIDE OUT View Post
... am going to replace all 4 tires with Goodyear endurance.
Excellent choice!
Old 06-17-2018, 08:14 PM   #4
p.s. I asked the same questions from several tire dealers; all said no problem.
They all said the LR E tires is supposed be at 80 psi to keep the sidewalls firm.
Old 06-17-2018, 08:15 PM   #5
Too old to be too smart
SpringerPop's Avatar
If you're not sure of your rim's pressure rating, you CAN use the Load Range E tires, but inflate them to only 65 PSI. Use metal stems if you can.
Then, use the weight-carrying specs for Load Range D tires of that size.
Or buy all new rims that CAN handle 80 PSI, and go with the carrying specs for L/R E's.
Pop
Terry 250RKS, perfect for the two of us and the pups.
It replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 06-17-2018, 08:43 PM   #6
member
Thank you for your feedback.Are you running with 80 psi?? if so how's it working for you
Old 06-17-2018, 09:47 PM   #7
Answer: Yes.
Ram2500 diesel / FR Surveyor 251rks
Old 06-17-2018, 11:25 PM   #8
Get the load range E. That is what I do with my Maxxis. Just fill them to what this table says for the load you are carrying.
https://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
See if any dealers carry the Maxxis. They are proven(been out longer than 18 months) and most dealers can get them quick. My boat trailer and TT have Maxxis on them.
2017 Coachmen 233RBS
2018 Ford F150 Lariat
"Common sense is not very common"
babock is online now   Reply With Quote
Old 06-19-2018, 04:47 PM   #9
Airdale's Avatar
That 2150# - orange above - is probably for a 5 lug/bolt hole wheel. Is that what you have? OEM wheels may have more than one rating on them. Does it read 5/2150? What does the certification label read for GAWR?
A Trailer Tire Poster
http://www.irv2.com/photopost/showfull.php?photo=15339
Airdale is offline   Reply With Quote
Old 06-19-2018, 05:12 PM   #10
Iwannacamp's Avatar
It's prolly one of these....
https://www.lionsheadtireandwheel.com/Wheels
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
replacement, tire
