Old 08-20-2013, 11:22 AM   #1
tire rim combo and hub studs
Hi new to the forum. Just tinkering with a pop up I just picked up 2000 flaggstaff. Needs new tires and of course I got one spun stud so far.....
Questions:
1. Stud size? Seems like I'd have to measure or match it up.
2. Recommended tire/rim combo or should I just find tires use the old rims? Recommends on where to buy em....Are all 4 lug trailer rim patterns the same?
Got the rest of the fall to get er ready then shell sit till spring so I'm prob gonna let the old tires sit over winter...
That's all I have for now. Appreciate the knowledge in advance,
Mike
blackngold19 is offline   Reply With Quote
Old 08-20-2013, 11:49 AM   #2
Dave_Monica's Avatar
Welcome to the forum!
Just take a measurement of the stud length and one of the lug nuts and try any automotive supply store. I'd be re-using the old rims and just mounting new tire. Just do a good cleaning of the bead area of the rim before mounting the new tires.
Should you decide to replace the rim, you'll need the same diameter, width and bolt pattern/circle. To find the bolt circle of the lug pattern, measure the lug centerline to lug centerline across the rim center.
Dave
tire
