Old 12-26-2013, 11:59 AM   #1
TURBS's Avatar
Tire rotation "who's right"
Ok so it's a "busy" day in the shop today so we're bench racing "bs session" and such.
The normal tire rotation on a vehicle is a matter of preference but I default to "fronts straight back" and rears "crisscross" to the front.
Which brings up trailer tire rotation.
There's obviously no steer tire and theoretically both axles are cambered the same.
So what is right?
Swap tires side for side but leave them on the same axle? "Tires will run the opposite way"
Or criss cross front to rear?
"Tires will run the opposite way and be on the other axle"
Or move tires straight forward and back on same side? "Tires run the same direction only on different axles?
What ya think?
TURBS
merry christmas to everyone on FRF !
Old 12-26-2013, 12:36 PM   #2
Helmsey's Avatar
I criss cross front to rear....no rhyme or reason as to why
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 12-26-2013, 01:07 PM   #3
TURBS's Avatar
Makes sense to me.
TURBS
Old 12-26-2013, 03:36 PM   #4
If you do not rotate trailer tires you can find axle aliment problems easier before it becomes a big problem. Just my opinion.
drc343 is offline   Reply With Quote
Old 12-26-2013, 03:41 PM   #5
wmtire's Avatar
Being ours is a tire shop, we don't usually delve into tire topics during our down time 'philosophical discussions'. We ponder the important things....like why are they called APARTments, when they are so close together.
Here are the recommended patterns for four tire rotations on vehicles.
2011 Flagstaff 831 RLBSS
Ive lost my scapegoat.
Old 12-26-2013, 04:06 PM   #6
Unless you are a full timer that logs a lot of miles, your tires will dry rot or seperate before they wear. If you do log the miles, front to back, no criss cross is fine. If you see abnormal wear, either something is bent (like and axle) or you have worn spring bushings.
Keep it Wheels Down!!
ChristianCamper is offline   Reply With Quote
Old 12-26-2013, 04:07 PM   #7
B47
That's as clear as mud - the chart shows A and B can be used on rear and four wheel drive vehicles and C can be used on FWD vehicles,but B can also be used.
Why not just say there isn't a specific tire rotation for these vehicles?
Old 12-26-2013, 06:45 PM   #8
Airdale's Avatar
Side to side to counter road crown/road camber.
A
Airdale is offline   Reply With Quote
Old 12-26-2013, 06:59 PM   #9
Twisty's Avatar
The only force applied to the tires is braking.
Right side tires go on to the left side and vicious vercious.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 12-27-2013, 08:14 AM   #10
Who rotates trailer tires? Mine usually dry rot long before they wear out.
jbrostek is offline   Reply With Quote
tire
