Old 09-24-2016, 08:09 PM   #1
gectisme's Avatar
Tire side wall bubble? Thoughts – advice?
I have been checking my tires regularly since I had some TV tire issues last month. Today when we arrived at camp I noticed the passenger side front Trailer tire looked strange. Upon closer inspection, there are what look like 2 indentations, (the red arrow points to one), and what I think might be a start of a bubble. If you can see it in the pics, thoughts and or advice please…
Was going to change it to the spare. The kicker is I have not ever inspected the spare, (OK, I know not so smart), and it seems to have the start of a bubble also but it is brand new never driven on. Again thoughts – advice? The last 2 pics are the spare. The top arrow points to an indentation and the other arrow points to a big area that seems like the start of a bubble. Can a tire never driven on have a bubble? Am I being paranoid?
ID:	121172   Click image for larger version
ID:	121173   Click image for larger version
ID:	121176   Click image for larger version
2016 Windjammer 3006WK
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper). Equalizer E4 1.4k/14k WD Hitch. TST 507 TPMS. Furrion FOS48TA Observation Camera. Garmin RV-760 GPS
gectisme is offline   Reply With Quote
Old 09-24-2016, 08:30 PM   #2
HONDAMAN174's Avatar
The pics of your spare are too dark to tell. As for your main tires, to me it looks like mold lines when they were made. Maybe a better mind like wmtire might chime in.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 09-24-2016, 08:32 PM   #3
Stank Bait's Avatar
It may be starting to separate at that point. I can see it. May be where the sidewall belts join, causing distortion. Hard to tell in pic. You can drive but why? Just asking for a problem. Take to get better opinion. Get tire checked at tire place.
2013 Flagstaff 831FKBSS
Stank Bait is offline   Reply With Quote
Old 09-24-2016, 08:33 PM   #4
wmtire's Avatar
I'm heading out the door for a few hours. Check my previous posts for the term "undulation" and it explains indentations and how to check if it's an indentation or bubble.
I'll find them when I get back back if you haven't seen them yet.
Edit; Here's one
Bulge in tire on both sides of rim
2011 Flagstaff 831 RLBSS
Hypochondria is the only illness I don't have.
Old 09-24-2016, 08:35 PM   #5
Your tires are Not New,they were prob made in 2015! Tires can "Lay Down" at any time! Replace with "Better Tires"! Do a Search at top of Page! Youroo!!
Old 09-24-2016, 08:50 PM   #6
gectisme's Avatar
wmtire, thanks! I think the spare is probably undulation but the one on the trailer seems to have developed the condition today. I will take a closer look tomorrow at both of the tires.
Old 09-25-2016, 01:43 PM   #7
I have had indents like that on tow vehicle tires. Drove like that for thousands of miles with no problem. A bulge or bubble would make me worry.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 09-25-2016, 05:45 PM   #8
I had the same issue with brand new tires. I took one of the tires of the fifth and took it into the dealer where I bought the tires. He explained that rather than being a weak spot it is a stronger spot due to the ever lapping of the belts. He mad a note on my file and assured me that the tires were completely safe to use. That was 18 months ago and no problems to date.
Larry Cole is offline   Reply With Quote
Old 09-25-2016, 06:05 PM   #9
Commercial Member
You might want to review my blog post on Bulge (out) vs depression (in)
The spare looks like depression. Better (more light) whould make it easier to see. Pictures of tires need LOTS and LOTS of light. Direct Sunlight is best. Also not just straight on shots. add some angle and side views too.
Sidewalls do not have belts but do have one or more layers "Ply" of rubber coated fabric. When being built there is a tolerance for the overlap. If too much overlap yes you do get a depression.
Old School but the parts are similar. He is building larger tractor radial but you should get the idea if you pay attention to the "splices" he is making to join the wraps of ply
More modern
I write a blog on RV tire application and safety. RVTireSafety.com
Also give seminars on tires at RV events across the US. 40 years experience as tire design & quality engineer for major tire mfg. Freelander 23QB on Chevy chassis is my RV
Tireman9 is offline   Reply With Quote
Old 09-25-2016, 06:18 PM   #10
gectisme's Avatar
My mistake - they are undulations, whew!
OK, I checked the spare and it is quite obvious on the other side of the tire, definitely undulation.
I don't understand how I missed them on the tire that is on the TT, I have looked at them numerous times in the past month and never noticed it. But I checked and sure enough the same indentations are on the opposite side but not as noticeable. Because there are 2 within 6-7 inches of each other, it makes it look like a bubble between them.
Thanks all for the wisdom, wmtire you know your stuff! I have never heard of undulations in tires before but then again, I never read much about tires until we got the TT...
here are some pics of the spare:
ID:	121290   Click image for larger version
tire
