Old 03-15-2014, 11:09 AM   #1
desman's Avatar
Tire size difference - Possible?
Currently have 205/75/15 D rated Japenese junk on my trailer. Going to purchase a set of Maxxis M8008. I would like to get their 225/75/15 E rated as replacements for the increased ply and load capacity if in fact there will be no issues mounting the new wider tire on the stock rims I currently have. Any issues with this?
2013 Salem26Tbud
2010 Ford F150 5.4L 4x4 3.55 gears
desman is offline   Reply With Quote
Old 03-15-2014, 11:15 AM   #2
225 x15 vs 205 x15
27.4"Dia. 27.11"Dia
8.86" wide 8.07" wide
Don't think you'll notice the difference. The 225's will raise the trailer .145" which is just over 1/8".
Old 03-15-2014, 11:23 AM   #3
fonzie's Avatar
This chart might help answer your question.
Trailer Tire Sizing | etrailer.com
Fonzie
Old 03-15-2014, 11:26 AM   #4
desman's Avatar
Thank you. Looks good to go. Should pose no problem with clearance between tire and sidewall of trailer...
2013 Salem26Tbud
Old 03-15-2014, 11:34 AM   #5
acadianbob's Avatar
Make sure your axles are far enough apart. On our trailer, there is only 2" between the tires for example, so a larger diameter could be a problem. Also, make sure about the pressure for which your rims are rated.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 03-15-2014, 11:39 AM   #6
Distance between tires will only decrease by 0.29"(little over 1/4") so it should not be a problem even with Bal X Chocks.
Old 03-15-2014, 11:44 AM   #7
desman's Avatar
Hmmm, I don't know off hand the exact distance my tires are apart from one another but I'm guessing 4 inces. As for pressure rims can handle, I have no clue or even where to look!
2013 Salem26Tbud
Old 03-15-2014, 11:50 AM   #8
desman's Avatar
Just an FYI, tires bought on Discounttiredirect ebay store until tomorrow have a $100 off total over $400 using code CMOTORS0314
Very good deal. 4 MaxxisM8008 out the door for $496
2013 Salem26Tbud
Old 03-15-2014, 11:53 AM   #9
Make sure you BALANCE them and have the high pressure metal stems put in that will take a TST TPMS system.
Old 03-15-2014, 03:20 PM   #10
desman's Avatar
Thnx Coot. In your opinion, you think that is the way to go as opposed to the standard "D" rated 205's?
2013 Salem26Tbud
tire
