Old 05-04-2014, 08:53 PM   #11
KDHfan's Avatar
I got the load range C. I felt that since my TT is only about 4500lbs loaded, spending the money to step up to a D wasn't justified. I just purchased a Tundra yesterday, so the odds are good that these tires only need to last this season. Lol.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 05-05-2014, 03:44 PM   #12
Guest
Yea, my 19' hybrid only lasted a season after I got my Tundra.
John4th is offline   Reply With Quote
Old 05-05-2014, 05:13 PM   #13
I run Hercules on my truck and 5th wheel. Truck tires are rated a 3400lbs trailer tires at 2150lbs. So far 15,000 on the truck and about 4000 on the trailer with no problems.
cadman99 is offline   Reply With Quote
Old 05-07-2014, 09:20 PM   #14
Commercial Member
Originally Posted by donanddona View Post
(KDHfan) Did you get the max speed for the tires you already bought? I believe the Marathons LR D are a 65mph max....
All ST type are 65 MAX. Think of that like an engine redline. Possible to exceed but you will eventually pay.
Also multi axle trailers should be running the tire sidewall pressure as cold inflation.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 05-09-2014, 11:38 PM   #15
the Hercules I am running are an ST tire, but are marked with an "L" speed rating (75 mph)
'07 Toyota Tundra 5.7L DC 4x2
'16 Surveyor 226RBDS
Nights camped 2016 - 3
Nights camped in 2015 - 20
Ditchooker is offline   Reply With Quote
Old 05-11-2014, 10:18 PM   #16
Commercial Member
Good to know that Hercules has established a Speed Rating for their trailer tires. I note that they have some trailer tires with higher load capability than some others.
The default on ST tires that do not have a Speed Rating from the tire manufacturer is still 65, lacking something in writing, from the mfg or molded on the tire sidewall from the tire.
tire
