Old 02-09-2016, 12:38 PM   #11
D_B Travelers's Avatar
Also recommend changing out your rubber valve stems on the tires for metal ones if you add a TPMS system. While the sensors are not heavy, they are still spinning at a pretty good rate which stresses the rubber stems, not to mention rough roads make them wiggle pretty good I would imagine.
D_B Travelers - 8 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 Ė 1996)
D_B Travelers is offline   Reply With Quote
Old 02-09-2016, 02:27 PM   #12
DodgeCamper's Avatar
I use the EEZtire System. It has worked great. you get some drops from the tire monitors but they pick back up in about 5 mins if they do drop off.
Very easy to setup and no need for an extender/repeater even with a 37 ft TT.
2015 RAM 2500 Diesel
2015 Lacrosse 329BHT
DodgeCamper is offline   Reply With Quote
Old 02-09-2016, 02:37 PM   #13
With the TST 507, I found it would drop contact occasionally when I had it suctioned to the windshield. Not wanting to spend $50 for a booster, I moved the unit to the left rear door window of the PU and it hasn't lost contact since. My DW keeps an eye on it while we travel and lets me know the pressure/temps if they look off. One thing about it, if it senses that pressure is down you will know...it is pretty loud! You can check for yourself by unscrewing one of the sensors from a tire and it sounds off. Also the TST battery life lasts several days when traveling.
Old 02-09-2016, 02:48 PM   #14
Originally Posted by Davidg View Post
I carry a Klein infrared temp gun with me any time I'm traveling. Every time I stop, I'll get the gun out and "shoot" the tires and wheel hubs. I'm not as interested in the specific temp as I am if one tire/hub is markedly higher than others. So far, they are always in a relatively narrow range. I've never seen tires higher than 136, hubs always cooler. The spare is always cooler yet....
"The spare is always cooler yet"
Thanks for the laugh!
dowjones is offline   Reply With Quote
Old 02-16-2016, 01:47 PM   #15
I just got my 507 out for the first time last weekend and I gotta say it was nice seeing the pressures up and temps stabilized. I previously called TST and they recommended 10% low and 20% high or even 30% high if it is hot out. The recommendation is to leave the temp setting to default.
Some guys have posted seeing higher pressure and temps on side of the truck exhaust when pulling long grades, I noticed a slight increase. Probably is n/a for motorhome unless pulling a trailer.
I noticed sun side as much as 5 degrees more than shade side. Ambient temp was as high as 88 mid-day and I saw trailer tires go from 50lbs to as high as 58lbs and ran up as high as 100 degrees temp. I was cruising @ 58-60mph with short bursts to 65 to make a run on a hill. I also ran it with the rubber stems but will upgrade to metal stems soon.
2015 Rockwood 8289WS
2003 Dodge Cummings
CraigBean7672 is offline   Reply With Quote
Old 02-16-2016, 06:49 PM   #16
Based on my observations one can expect a 10-20% increase which, according to tire mfgr's. info, is factored into the tire's ratings.
phillyg is offline   Reply With Quote
pressure, tire, towing
