Old 04-09-2013, 09:01 PM   #1
ryand's Avatar
Tire Wear/Alignment
2011 Coachmen-
Have noticed inside rear axle tire wear to the point there is a noticeable diff. between front and rear. I talked to a local shop today and they said they could check the alignment.
Having read a ton of info on this forum it appears there is no real adjustment on the dexter axles other than bendining the axle tube. Just viewing the axle from the rear it definatly looks like the camber is off.
Weighed the trailer and have roughly 1000# left so not over weight...but i dont know what the previous owner did. Looking at the upcoming season I wanted to make sure eveyone is safe and there is no issues.
Any one have their Dexter axles aligned? Is it possilbe?
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 04-09-2013, 09:07 PM   #2
ryand's Avatar
Better Photo
Old 04-09-2013, 09:14 PM   #3
wyo700's Avatar
It is possible to align the axles. I worked in a small shop that did trailer alignments. In your case I could see putting the bottle type jack on the vey bottom and pumping until it bent your axle the other way. The way we would do it is the jack would hang from chains and could be swung around for which ever way the axle needed to be bent. It was a set made specially for trailer axle alignment.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 04-09-2013, 09:25 PM   #4
DDC
DDC's Avatar
Make sure the axle is mounted properly, the bow should be up yours looks down although its hard to tell just by this picture.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 04-09-2013, 09:41 PM   #5
ryand's Avatar
Bow is down.
Old 04-09-2013, 09:44 PM   #6
Originally Posted by ryand View Post
Bow is down.
If it doesn't have springs, I don't think it's mounted wrong and you may be able to have a shop bend it up. Are both tires on that axle wearing funny?
Old 04-09-2013, 09:46 PM   #7
ryand's Avatar
It has leaf springs...both tires are wearing on inside edge. Same axle.
Old 04-09-2013, 09:53 PM   #8
Prime candidate for the shop, they can bend it!
Old 04-09-2013, 09:57 PM   #9
VinceU's Avatar
Sure looks like excess neg camber, I'd be asking Dexter and a alignment shop for advice. Also ask what could have caused it.
Old 04-10-2013, 12:50 PM   #10
ryand's Avatar
Talked more with the truck shop..something they see often. In my case, don't know what the previous owner did but often If the TV is a jacked up truck the trailer is not level it can put more load on the rear.. Also overloading the entire thing can be an issue but typically both axles bend negative. They can also be installed upside down at the factory. Also said the frame fabricators pile frames on top of each other and the one carrying the load sometimes is the one that goes under our units. Scary!
