Old 07-08-2015, 05:24 PM   #11
mtnjeepers's Avatar
had a blowout on my way to So.Dak. go to Rapid City and put new tires on my W&P.
put on 235/85/16 goodyear G614 expensive but worth the piece on mind.
mtnjeepers is offline   Reply With Quote
Old 07-08-2015, 07:02 PM   #12
Commercial Member
I trust you confirmed the location and reason for the air loss that caused the Blowout. If for example if the air leak was caused by a loose bolt in tire valve you could end up with just another failure.
A TPMS should have provided warning of the air loss that resulted in the Run Low Flex Failure of the tire sidewall i.e. the "Blowout"
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
tire
