Old 04-04-2012, 11:16 AM   #1
Tires for a 2007 Wildcat 29 BHBP
I currently has 225/75R15, but I don't know what rating of tire should I get D or E?
Thanks,
radi_33125 is offline   Reply With Quote
Old 04-04-2012, 11:53 AM   #2
pbrackney's Avatar
What is your trailers GVW?
Philip, DW, 3 DD, 1 DS, and Ginger our Dog
2017 Wildwood 30QBSS
2003 Ford Expedition 5.4 Liter with 3.73 Axle
Equalizer 4-Point Sway 12000# & Tekonsha P3
pbrackney is offline   Reply With Quote
Old 04-04-2012, 12:19 PM   #3
No matter what your best choice is Maxxis unless you upgrade to 16 inch tires.
Old 04-04-2012, 12:37 PM   #4
pbrackney's Avatar
After looking at your trailer model online I would go with Class E just to be safe. Donn is right that the Maxxis tires are the best. You can find them at Discount Tire Stores. Camping World carries Goodyear Marathons. They are a better tire than in the past but the Maxxis are still better. They will be more expensive as well.
Old 04-04-2012, 12:52 PM   #5
My GVW is 11,500.
Old 04-04-2012, 03:45 PM   #6
JAYCO Representative
Wildcat Chris's Avatar
All new Wildcats run on E-rated tires...
Wildcat Chris is offline   Reply With Quote
Old 04-04-2012, 05:12 PM   #7
With that GVW, I would go with the 'E' rated tires.
Old 04-04-2012, 05:34 PM   #8
Dave_Monica's Avatar
The other issue is the rating on your rims. They may not be rated high enough to run the recommended 'E' range pressure of 80 psi. I believe that the max pressure rating is stamped on the rim.
Dave
Old 04-04-2012, 06:04 PM   #9
If you have to upgrade wheels might as well go to 16 inch LT tires.
Old 04-04-2012, 06:10 PM   #10
TURBS's Avatar
what donn said .
Old 04-04-2012, 07:09 PM   #11
Oh gawd, not the "LT" tire guys again!
Old 04-04-2012, 07:11 PM   #12
That's 'LT' as in Light Trailer, right!
Dave
Old 04-05-2012, 08:32 AM   #13
I think I am going to go with the Maxxis 8008 load range E?
Old 04-05-2012, 09:30 AM   #14
pbrackney's Avatar
Great choice!
Old 04-05-2012, 08:22 PM   #15
Thanks for all the help; she got 4 new Maxxis load E today.
