Old 10-12-2016, 08:58 AM   #1
tires not right size for trailer???
I have a 2013 Wildcat 282RKX .31 ft. I noticed the tire size after my first China bomb blew out over the weekend. My tire size is ST225/75/15r, but all the procures, paperwork sales receipts all say ST235/80R/16E so what happened to my 16's. A big difference?? Should I have 16's on my trailer???
Pflugerville, TX
2013 Wildcat 282RKX
2012 Ford F250 Super Duty 4x4 tow vehicle
RV there yet!
Tim966 is offline   Reply With Quote
Old 10-12-2016, 09:05 AM   #2
SeaDog's Avatar
Check your trailer build date it may be your rig is listed as a 2013 but was an early build and the units at that time might have had 15" rims. With that said if your sales receipts say 16" you might have some recourse by going back to the selling dealer.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 10-12-2016, 09:12 AM   #3
wmtire's Avatar
Does the placard/sticker on the side of the trailer say 15 or 16?
2011 Flagstaff 831 RLBSS
I've invented a new word. "Plagiarism"
Old 10-12-2016, 09:15 AM   #4
16" tire were and option when I ordered our 2015 282RKX. Standard are the 15" tires and wheels.
keizer_or is offline   Reply With Quote
Old 10-12-2016, 12:21 PM   #5
muddyrode's Avatar
my 2012 32RL has the ST235/80R/16E tires on it
and that is what white sticker on the front left corner
says should be on it
2012 wildcat sterling 32RL
2013 3500HD DRW Silverado Duramax
Remember slow and steady wins the race
muddyrode is offline   Reply With Quote
Old 10-12-2016, 12:22 PM   #6
Phat Phrog Stunt Crew
elind's Avatar
It could depend on you RV weight that were matched up to tires needed. My Wildcat 327ck weighs 10,500 dry and has 16" on it. If your 31' Wildcat only weighs 7-8,000 lbs it may need only 15" wheels. But if you could upgrade to E rating tires that would work.
elind is offline   Reply With Quote
Old 10-12-2016, 12:27 PM   #7
elind's Avatar
Muddyrode, I have 18,000 miles on mine and going to change out after I get to Az.
2014 Wildcat 327ck
2015 129 nites
2016 63 nites
Old 10-12-2016, 01:18 PM   #8
Airdale's Avatar
There's not much in the form of recommendations that anyone can do without the information from the trailer's certification label. It's going to be found on the LH external section of the trailer.
If your tires are the original tires that came with the trailer and they are the same size as displayed on the certification label and when inflated to the recommended inflation pressures also depicted on the certification label, they will be the correct tires.
On the other hand, if they do not match the certification label and are in fact the OE tires then inform FR of their mistake and get some new tires, free. If FR does not respond send all info to NHTSA and they will force them to respond.
USN - RET
DOD - RET
SSA - RET
Airdale is offline   Reply With Quote
Old 10-12-2016, 02:52 PM   #9
NMWildcat's Avatar
There's always another scenario...
We bought a Jazz fifth wheel a few rigs back with nice rims and upgraded tires. When we went to pick it up, we discovered the dealer had switched the rims and tires, and also took out the good mattress and replaced it with a crappy one. Funny how when we refused the purchase, all those things showed up again real fast. Even got some nice folding chairs thrown in Turned the dealer in to Thor and the BBB.
Hopefully your dealer didn't pull the switch-a-roo on you. Probably not as they would of had to switch rims and hubs/axles.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 10-12-2016, 03:14 PM   #10
After further inspection of the cert. labels on the front of the camper it has St225/75/15/ load e , dry weight of the camper is 8021. So I guess the tires on the camper are the right ones to have on it. I hear people taking off the ST and putting on 16" rims with 16" light truck tires like Michelins. any response to that?
Pflugerville, TX
2013 Wildcat 282RKX
RV there yet!
tire, tires, trailer
