Old 11-30-2013, 05:02 PM   #31
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Originally Posted by gljurczyk View Post
Lloydg, The rim is either stamped on the back or inside with the max PSI. depending if they are steel or alloy where it will be located. I have the same unit as the person who started the thread, I just got new tires, so I know his rating also.
Do you mean that if I can't find it on the back of the rim I will have to remove a tire to find out?
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 11-30-2013, 05:05 PM   #32
Ford Idaho's Avatar
Yes.
Or have a tire shop do it for you.
Old 11-30-2013, 05:09 PM   #33
Actually this was discussed at length in some thread here. I think it said there there may be no marking on some aluminum wheels and you just have to find them on the manufacturer's website to find out what the rating is.
Old 11-30-2013, 05:49 PM   #34
Witch Doctor's Avatar
Lloydg, I found mine by the web site of the rim. Mine had a www. web address on it. Then it went by the bolts and spokes if I remember right. I do think it is the law that the manufacturer stamp the max PSI somewhere on the rim. I remember Herk's was stamped on the rim but his was steel rims. If I remember right. most of the time an alloy rim will be on the inside. here is a web site for mine but yours might be different but you will get an idea. www.series06.com it will explane the PSI by bolt and spoke pattern. just click on the link. Hope it helps you
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 11-30-2013, 06:01 PM   #35
Bottom line, to answer your question, if your rims are rated for 50# and you inflate to 65 or 70, you are risking a rim failure which could mean it just splits if it is a steel rim. There is no doubt a safety factor built into the rims, but, "it's not nice to fool Mother Nature". If it is an alum wheel they could just break and IMO would be more dangerous as the break would no doubt involve pieces of the rim being propelled like a grenade. If you have the 15" 06 alum wheels, they are rated for 65# so you can go to a LR D tire.
Old 11-30-2013, 06:26 PM   #36
Thanks OC I think that is the original question to begin with, It's about time you chimed in. I would never inflate mine to 80 lbs PSI for that reason. and went with the Marathon D rating. Hope your traveling is going okay...... I'm still in this ice box they call Virginia...
Old 11-30-2013, 06:30 PM   #37
Was 24° when we left Concord yesterday morning, got to Daytona and it was only 74°, was expecting at least 76°+.
