Old 01-30-2014, 10:10 PM   #1
tires, wheel.and weight limits
Hi everyone. New owner of a flagstaff 8528IKWS that finally got weighted. At the present time all numbers are OK, but one parameter has drawn my attention! It was delivered with Load range C tires and I'm considering going to LR D tires for some safety margin. When I consulted a local tire dealer he pointed out that I needed to investigate the wheel capacity of the factory provided wheels. They have a 2150 pound limit! This give 8600 pound total capacity. Dangerously close to the weight without any water aboard. New wheels with a 2500 capacity are hard to find or are really expensive when added to the cost of new tires with the D load range. Can any one suggest where I might find reasonable wheels. I checked several tire dealers without success. Thanks
Bonnie & Bob
2014 Flagstaff 8528IKWS 5'er with revolution hitch
tv: 2014 Lariat Ford F250 power stroke
L'il Red Wagon 6.5 bed
bobby75 is offline   Reply With Quote
Old 01-31-2014, 12:53 AM   #2
Dave_Monica's Avatar
You camper may be 8600 lbs loaded, but only about 7100 lbs is carried by the axles...the rest is pin weight. The OEM tires are always higher than the axle capacity...in your case a 4000# axle rating and 2150# rated tires.
Many other Rockwood/Flagstaff 5ver owners have changed out the OEM 225/75R15C tires for 225/75R15D, but the load limit is still the axle rating of the camper.
Dave
Old 01-31-2014, 07:07 AM   #3
Dave
Dave;
The trailer was weighed with the 5th wheel already hooked up to the truck ( truck off the scale), I was under the impression of other posts and instructions that at configuration already accounted for the pin weight as being on the truck, not the trailer. The weight of the trailer loaded (almost fully) with the pin weight transferred to the truck was about without water was about 8300. I'm confused.
Bonnie & Bob
Old 01-31-2014, 07:37 AM   #4
Fulltime family RVer
Bob, can you post your various weights and what configuration your truck/camper was in relation to the scales?
Old 01-31-2014, 08:04 AM   #5
Originally Posted by bobby75 View Post
Dave;
If you're saying that the scaled weight of 8300 is what's on the camper's axles and the camper's hitched to the truck and the truck is off the scales, you're overloaded. The max weight on the axles of your camper is 8000 lbs (4000 lb axles)...changing wheels/tires won't cure that.
Dave
Old 01-31-2014, 08:17 AM   #6
Sure can:
Truck alone: 8620# fully loaded with passengers fuel, etc.
Trailer two axles: 8680#
Trailer back axle only: 3320#
Trailer front Axle only: 5500# by subtraction
Truck plus trailer: 18960# GCW GCWR 23500#
When weighed there was some snow on, maybe 4 inches.
The labels on the trailer indicated from my notes:
GVWR: 9389#
GAWR: 8000# If you subtract the "listed " pin weight of 1300 you are 89# over GAWR
I am concerned about the rim capacity of the FR provided rims.
Also seems a waste to put on D rate tires with 2150# rim capacity with 2500# D rated tires!
Bonnie & Bob
Old 01-31-2014, 09:15 AM   #7
Using the numbers you provided:
Total camper weight = 18960 (total combined wt) - 8620 (truck alone) = 10340 lbs
GVWR for the camper is 9389 and therefore 951 lbs over.
Pin weight = 18960 (total combined wt) - 8620 (truck alone) - 8680 (trailer axle wt)
= 1660 lbs
Trailer axle weight of 8680...camper axle wt rating 8000...680 lbs over.
I'd have a tough time believing that the front and rear axle would be that different...may be some error there. You may want to repeat the entire process to confirm the numbers. (edit: without the snow on top)
The rim and tire load capacities are the least of your problems IMO.
Dave
Old 01-31-2014, 09:55 AM   #8
kerrlakelover's Avatar
= 1660 lbs
Dave
Dave, you and ependad seem to always be the most knowledgeable on this weight subject. But, if his FW is not sitting level when attached to the tow vehicle, axle weight can vary widely. I saw it with my FW when I measured it prior to lowering my hitch and leveling out the FW. Only a couple of inches makes a big difference in axle wt. But, Bob's must be 6" lower in the front with that much difference. :-)
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
kerrlakelover is offline   Reply With Quote
Old 01-31-2014, 07:06 PM   #9
OK, Lets try this again with a new perspective on the numbers I reported earlier. My first weighing was on 1-9-13 just the truck only trailer not hitched to the truck: 8620. the remainder of the weights were taken on 1-14-14 with the weighmaster instructions relayed to the driver as results as follows:
Ticket#1727 annotated as front axles 4800#(presumed to be truck)
Ticket#17128 annotated as 2 truck Axles: 10320#
Ticket#17129 annotated as complete (truck and trailer):18960#
Ticket#17130 Annotated as trailer 2 axles:8680#
Ticket#17131 annotated as trailer back axle:#3320
Since I did not check his placements I can only guess they were correct as far as my instructions were concerned! HOWEVER,
there was one other ticket #17132 which I did not tell him to do - annotated rear axle truck and both trailer:14120#
I'm considering a reweigh at a different scales I though I'd run these clearer numbers as to whether or not I'm overweight.
Thank for you help and patience.
Bob
Bonnie & Bob
Old 01-31-2014, 07:45 PM   #10
Herk7769's Avatar
This is SO TRUE. My 5th wheel camper rides only slightly nose high and the leading axle carries 90% of the camper and the rear axle carries 110%.
I discovered this when after a 9,000 mile trip last year my leading axle tires showed "over pressure for weight" wear pattern and the rear axle tires showed "under pressure for weight" wear. They were properly inflated (I thought) for the maximum scaled weight on the camper's axles.
HAM CALLSIGN - KC3FFW
tire, tires, weight, wheel
