Old 07-15-2012, 08:52 PM   #1
Tires wore out on the inside edge
I am going to be calling my dealer in the morning. Just got back from a week long trip and discovered on the way home today that the inside edge of all 4 tires are wore out. The trailer only has about 5K on it. The date code on all four tires are Dec 2010 (if I read it correctly). The tires are Trail Express. With the tires wearing on the inside edge is it just bad tires or something worse like axle or hub issues. The rear tires are worn a little more then the fronts. I am going to try to attach the pictures that I took as it was getting dark.
ID:	16561   Click image for larger version
ID:	16562   Click image for larger version
ID:	16563   Click image for larger version
Paul & Karen and the 2 Little ones in tow.
2007 Nissan Armada LE
2012 Wildwood 26BH XLite
20 Nights campled in 2011.
25 Nights Planned for 2012!
pandkm is offline   Reply With Quote
Old 07-15-2012, 09:00 PM   #2
wyo700's Avatar
Wear like that I am gonna say its axle problems. And not saying you did it on purpose but that can happen from the trailer being over loaded making the axles bow and all the force being put on the inside of the tires.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 07-15-2012, 09:01 PM   #3
If it has springs, I would suspect either the axles are installed upside down or the axles are bent. Either way, it needs to be taken back to the vendor. Look under the trailer to see if the axles are bowed up in the center. If the bow is down, they are upside down. If they are bowed up, there is a very remote chance the wheel bearings are loose on all 4 wheels, but that is a very remote possibility. A trip to the dealer is necessary either way.
Old 07-16-2012, 03:00 PM   #4
Called the dealer this morning and he said that they are the cheap Bias tires and a year and half on them is good. he asked me to email the pictures that I had and to bring the trailer to him when I had some time that he was going to double check the axles and hubs but by looking at the pictures he expects it to be nothing but bad tires. He hates those tires.
Old 07-16-2012, 03:02 PM   #5
Dealer just called me back as I submitted the last post. He shipped the pictures to FR and they are going to credit me 50 dollars a tire and the dealer is going to give me another discount on top of that. He is still going to inspect the axles and stuff to make sure that there is nothing else wrong. Now just to find time to get the trailer to him. And then to decide what tires to get. Stay with Bias or go with Radial.
Old 07-16-2012, 03:54 PM   #6
Radials would be my choice and about the only thing that will make all 4 tires wear on the inside has to do with the spindles or the axles. Tire make has nothing to do with it. Another way to check is drop a plumb bob down the side of the trailer on the centerline of each wheel and measure from the string to the top of the rim and the bottom of the rim. It should be the same or maybe a little closer at the top. If it is closer at the bottom, it is a spindle/axle problem.
Just make sure the trailer is on level ground.
Don't let the dealer blow smoke up your...
Old 07-16-2012, 04:20 PM   #7
amxpress's Avatar
While they're at it, have them balance the new tires.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 07-17-2012, 02:52 PM   #8
RPAspey's Avatar
and put on metal valve stems. not 65# rated rubber ones!
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 07-17-2012, 04:15 PM   #9
I have had same problem for 6 years on my 30 ft fifth wheel model 28rk. Had axles checked for alinement at campingworld Springfield,MO July 7 and found out frount axle was within 1/16 in. rear axle was over 1/2 inch out of aline and making axle dogtrac causing tires to wear on out sides. Hope you don't have this problem.
gramps1 is offline   Reply With Quote
Old 07-17-2012, 04:55 PM   #10
DAISY BOYKIN's Avatar
Have to agree with all above post--------
Have to agree with above post including AMXPRESS that they need balancing!! One of your pictures looks like the tire is cupped (OUT OF BALANCE).
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
DAISY BOYKIN is offline   Reply With Quote
Old 07-17-2012, 04:56 PM   #11
lindy's Avatar
One point not mention so far is, have you weighed the trl yet? You wouldn't believe how easy it is to overload the trl and tire wear as show is one result.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 07-17-2012, 05:11 PM   #12
Big Dawg's Avatar
I am having the same problems with my 2011 Grey Wolf. It is at the dealer now, they are working with Lippert to replace the axles, and they will cover the tires. I am in a waiting game with them.
2004 Chevy Avalanche Z66 W/Transmission Cooler
2011 Grey Wolf 28BH
Blue Ox Sway Pro WDH
2 Beagles (Snoopy & Dexter)
Big Dawg is offline   Reply With Quote
Old 07-21-2012, 04:28 PM   #13
BJAY's Avatar
I had something similar happen on a single axle trailer 2 years ago. We had made a 6000 mile trip from Toronto to Brownsville, Tx with no noticeable tire wear. The next year I added a WD hitch and had to replace the tires when I got home. Before installing new tires I had the axle alignment checked and all seemed good. The old tires wear load range C so I upgraded to Load Range D tires and had 12000 miles on them when I sold the trailer. I thought maybe I was transferring enough extra weight to the trailer axle with the WD hitch to overload the C tires.
Bill
Bill & Joyce
2012 Hemi Ram 1500 Quad cab 4x4
2011 Wildwood 22RBXL-Backpack Ed.
BJAY is offline   Reply With Quote
Old 07-21-2012, 08:03 PM   #14
if it has the lippert axles in it, it's probably bent incorrectly. Had mine replaced for wearing like yours just over a year ago. FR stepped up and paid for the new tires as lippert wouldn't cover them. I did catch mine quite quickly (within 6 months) of purchasing the trailer.
'07 Toyota Tundra 5.7L DC 4x2
'16 Surveyor 226RBDS
Nights camped 2016 - 3
Nights camped in 2015 - 20
Ditchooker is offline   Reply With Quote
Old 09-04-2012, 10:34 AM   #15
Well know that it has been a while but the dealer finally got to my trailer. They were going to charge me for an axle inspection that I declined hoping that someone who say something. Well the tech was looking it over and told them that if he just put new tires on it that they would just wear out again. lippert is sending new axles and tires. I am adding the metal valve stems and having them balanced. Axles should be here sometime this week. Thank goodness for good service techs.
