Old 04-14-2016, 09:24 AM   #11
Commercial Member
Blackhat6mike
Did you file a complaint for each failed tire with NHTSA? If we (RV community) don't file complaints then the quality of tires will never get improved.
Good descriptive pictures of Tread Separation of radial tire.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 04-14-2016, 09:27 AM   #12
Commercial Member
Originally Posted by Davidg View Post
I used a local mom & pop tire shop. Since air is 80% nitrogen, I think it's a hoax. 80 psi. No, I just bought 4, although I considered 5. I figure since the original spare is not old and hasn't been on the road yet, it will serve as a spare for a year or so. You are doing the best first step by becoming informed. Good luck, and let us know what you decide.
Where does your spare mount? If not under the RV but on back bumper it is imperative that you have a light color (white preferred) cover for the tire. I have seen tires have belt/tread separations with zero miles use.
I understand the technical reasons which aren't important now other than to say the failure can be delayed or prevented with proper steps.
tire
