Old 07-17-2012, 11:06 PM   #1
Tongue Jack Overextended?
Ok, so I just got home with my brand new Salem 26TBUD, this is my first trailer of any kind. Taking it off the hitch for the first time, I crank it up enough to unhook all the WD bars, chains, etc. Then go to crank it up higher to get it off the ball. It's not going high enough, so I foolishly kept cranking even though it was giving resistance. Then I heard a sort of 'pop' and the crank began turning rather freely, but not moving anything. So, it seems like I may have overextended it.. Any way to get this thing back engaged?
Yes I realized afterwards I was being a total newb and should have put a block under the jack to get the additional height I needed to get it off the ball.
After an event-free 3-hour ride home I just knew something had to go wrong.. hopefully it's nothing major.. thanks!
nullvalue is offline   Reply With Quote
Old 07-17-2012, 11:11 PM   #2
TURBS's Avatar
IT should re-engage but you may have to use a floor jack to take the weight off it .
Old 07-18-2012, 12:23 AM   #3
Rsgtivr6's Avatar
Sounds odd that it would stop cranking before it cleared the ball. It should get that height easily. Is there a hole under the jack? If not, there should not be a need to add blocks to get the height to clear the ball. Otherwise, how did you get it connected in the first place? Sounds to me like it bound up and maybe broke something. If it wont re-engage with the screw, I smell a warranty call, and even then, I would still call the dealer and tell them that it happened. They might offer a new one just in case something is damaged inside.
TV: '17 Ram 2500 Big Horn CCSB CTD 4x4
TT: '18 Wolf Pack Limited 325Pack13
Tow Acc: Andersen Ultimate Hitch 2 goose ball mount, AirLift 5000 bags and HD compressor system
Rsgtivr6 is offline   Reply With Quote
Old 07-18-2012, 12:36 AM   #4
Terier's Avatar
Is the trailer still connected or were you able to unhitch?
Terier is online now   Reply With Quote
Old 07-18-2012, 08:13 AM   #5
PINTO
Kpinto's Avatar
Those screw type jacks are known for this. As you stated you exceeded the maximum height, then when you forced it you broke it. I am speaking from experience here. (LOL) There is a plate in the jack that moves up and down on the long threaded shaft. That small plate is tack welded to the hollow shaft that actually pushes the trailer up. When forced, the weld breaks.There is no way to fix this because you can't get them apart. Or at least I couldn't. My brother in law done exactly the same thing. I replaced the jack. Only about 60 bucks for the one I needed. To me this sounds like what happened anyway!
PINTO
2011 Flagstaff 8528 TBWS
2008 Duramax Diesel
Chevy 3500 LTZ Dually
Kpinto is offline   Reply With Quote
Old 07-18-2012, 08:31 AM   #6
Thanks Yeah I was kind of surprised it didn't go high enough too.. haha and no hole under the jack, just a small piece of 2x4. Yes I'm definitely calling today. I actually didn't connect it in the first place, the dealer did it for me before I left.
2006 Ford Expedition Eddie Bauer
2013 Salem 26TBUD
Old 07-18-2012, 08:32 AM   #7
I was able to unhitch.. I have a WD hitch so I pulled the pin on the box and drove off a foot to disengage, leaving the 50+lb ball hanging there which I quickly released.
2013 Salem 26TBUD
Old 07-18-2012, 08:34 AM   #8
TURBS's Avatar
Check your local farm supply for a new one. Rv stores think there GOLD!
I bought one a few years ago @ farm and fleet (bull dog) brand for $29.00
Worked great.
Old 07-18-2012, 08:36 AM   #9
Thanks I'll see what the dealer service guys say.. BTW I'm thinking the reason the jack couldn't extend high enough is because while my trailer was sitting on my level driveway, my truck was on a slant in the front part of my driveway. There's maybe a 6" grade drop there, making the rear end sit higher... who knows
2013 Salem 26TBUD
Old 07-18-2012, 08:37 AM   #10
acadianbob's Avatar
Don't know where you live but I bought a 5,000 pound Bulldog manual crank jack at Northern Tool for $29. It works great. Bolts right in. Good luck.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
