Old 08-16-2012, 11:17 AM   #1
Question Torque on R14 Viking travel Trailer (Solved)
Hi
I have a 14R Viking Travel Trailer 2012. The rims are Dextar and say maxium torque should be 75 lbs. Viking manual says 95 lbs yet in talking to them in person they say 75 lbs and my dealer says 100 lbs.
Looking for a answer.
spinedr is offline   Reply With Quote
Old 08-16-2012, 11:25 AM   #2
Originally Posted by spinedr View Post
Hi
Are they aluminum?
File Type: pdf Flagstaff TT Alum Wheel torque specs.pdf (311.4 KB, 35 views)
Old 08-16-2012, 11:30 AM   #3
No they are steel.
Old 08-16-2012, 11:39 AM   #4
No they are steel.
I would still use the torque values in the pdf file. With them being steel, you just need to torque them after about 50 miles and then every once in a while after that. Alum wheels are a pain to finally get them torqued. Usually takes 3 or 4 times with 50-75 miles between torques. After they are once seated, I only check them before we go on a long trip.
Old 08-16-2012, 11:42 AM   #5
Thanks for the info
Old 06-21-2013, 09:23 PM   #6
Will a full size mattress fit where the dining booth is when made into a bed?
kathy09 is offline   Reply With Quote
Old 10-23-2014, 06:04 PM   #7
mdgladfelter's Avatar
kathy09 - In a 14R when the table is converted to a bed, it is the perfect size for a futon mattress from Walmart. Also full size sheets does the trick and fit very well.
mdgladfelter is offline   Reply With Quote
torque, viking
