03-24-2018, 11:27 AM
Torque specs for trailer wheels?
Any ideas where I would find torque specs for trailer wheel lug nuts? New trailer with good old Chinese Castle Rock tires. 225-75-15. I've looked through the literature they gave me but can't find anything. Thanks!
Brian and Tracy
2017 Flagstaff 26FKWS
2019 GMC Sierra 2500 Denali
6.0 Gasser 4:10
03-24-2018, 11:34 AM
Torque specs are determined by Dia.of wheel lug! Some wheel MFG have odd Torque specs between "Steel & Alum"wheels also? E Trailer has spec sheets for most Lug/Wheels! Youroo!!
03-24-2018, 11:35 AM
Scoundrel
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
03-31-2018, 02:39 PM
On my trailer there is a small white sticker just above the wheel well stating torque required for the wheels, might try looking there.
Edit: I stand corrected, sticker is at the front passanger side of the trailer, 100 ft/lbs in star pattern.
06-01-2018, 05:03 PM
I have that sticker but they didn't fill in the needed data...useless
2017 Ford F 150 XLT FX4 3.5L EB 10 sp trans
2017 Salem Cruise Lite 171RBXL
06-01-2018, 05:37 PM
Our new 2608SB came with a big sticker on the front saying the wheels had been torqued to 100 lbs.
When wheels were balanced, the mechanic thought this was a bit low and torqued them to 110 lbs. I checked after about 60 miles, got a little movement, and re-tourqued them to 110. I'll check again after our next trip.
BTW .... here's a surprising thing .... When balancing the wheels, it was discovered none of brake housings had the rubber plugs installed in the brake adjustment holes. Not a good thing!!!!
Might be worth a check to see yet another thing the factory 'forgot' to do!
Cheers,
John
06-02-2018, 04:17 PM
If you have a copy of the trailer's owner's manual, the information you seek will be in the tire section.
A Trailer Tire Poster
06-12-2018, 06:28 PM
Does anyone know what the size if the nuts are? I have a 204rd and can not locate anything. Both the 19mm and the 3/4 size fits the lugs. I want to have the right one if something goes wrong!
06-12-2018, 06:35 PM
Gold Tee Box
19MM equals .748 inch, both will work fine. There is likely more tolerance in the manufactured lug nut itself.
Success is hiring someone to mow your lawn so you can play golf for exercise.
2018 GMC 2500 Duramax Denali
2018 Coachman Freedom Express 287BHDS
06-12-2018, 06:38 PM
Thanks.
06-12-2018, 06:39 PM
NH Maple Maker
Either socket will work because 3/4" and 19mm are actually the same size.
Russ
2014 V Cross VIBE 822VRBS
2017 Silverado 1500 crew cab 4x4
06-12-2018, 07:01 PM
Gold Tee Box
Still waiting for someone to reply that it really doesn't matter as long as you are towing it with a 1 Ton Diesel...
09-07-2018, 06:43 PM
I always torque the lug nuts on the RV to 105# before every trip along with an air pressure check. We are half way through a 6000 mile trip, travel about 350 miles a day when traveling staying several days here and there. Our trailer has aluminum wheels, I use a 3/4" six point deep well socket with a 2" extension and a 24" click stop torque wrench. Never fails that one or two lug nuts will move ever so slightly but I do feel the movement. It's rare if I see another camper checking the torque of there lug nuts. I wouldn't feel safe not checking before a days travel. Am I paranoid? Do most have this issue with aluminum wheels?
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
