01-05-2020, 05:43 PM
#21
Originally Posted by Lee Pedrick
Google up torque settings for American and metric nuts and bolts. Torque settings are rated for the size of the Nut/ bolt.
That will also depend on the grade of the bolt. i.e. grade 5 vs. grade 8, etc.
'19 Chevy Colorado Z71 4x4 Crew Cab
'17 Salem Cruise Lite 232RBXL
Mickey the Rescue Project Schnauzer
Days Camped: '17-39, '18-61, '19-64, '20-38
01-05-2020, 05:46 PM
#22
Originally Posted by AlaskaErik
Just remember to zero out your torque wrench after you're done using it. Otherwise, you'll lose your calibration.
x2.
You can also calibrate most torque wrenches.
https://www.wikihow.com/Calibrate-a-Torque-Wrench
01-05-2020, 08:16 PM
#23
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
01-05-2020, 08:59 PM
#24
Originally Posted by NJKris
Sticker on my trailer say 100 ft-lbs. My torque wrench doesn't go up to 100 ft-lbs. So I stand on a wrench 0.4 feet away from the socket to exert 100 ft-lbs. (I am 250 lbs. torque = force applied at 90 degree angle (perpendicular) x radius (distance from pivot point, or lug nut). 100 ft lbs/250 lbs (ME!) = fraction of foot distance from lug nut to exert force.
Stand on does not mean jump on it, just exert a smooth downward pressure until nut stops rotating.
See? Physics can be fun!
And now I have a headache
2016 wildwood x-lite 241qbxl
being jurked down the road by the beast 2007 Dodge ram 2500
5.9 cummins g56 Trans southbend clutch and a smarty
01-05-2020, 09:01 PM
#25
Most steel wheels torque between 90 and 100
Aluminum 100 to 110
01-05-2020, 09:15 PM
#26
Originally Posted by frank4711
I'm sure that one is better, but for my needs, this $20 one works fine
https://www.harborfreight.com/12-in-drive-click-type-torque-wrench-63882.html
And, better yet for those in the market, it's on sale next weekend for $10.
Be sure to get the 1/2 inch drive. The 3/8 inch will likely max out too early for your RV's lug nuts.
01-05-2020, 09:23 PM
#27
https://www.harborfreight.com/12-in-...nch-63882.html
yep for sure ... think I paid $79 on sale ... with the camper gets used a lot ...
01-05-2020, 10:10 PM
#28
This thread has convinced me to go out and purchase a HF torque wrench. I just hope I can get hold of one of HF's "rare" coupons. With any luck I'll also score a free flashlight or tape measure.
2015 Shamrock 23IKSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
01-05-2020, 10:12 PM
#29
I do my track car, ‘17 mustang gt at 95 so I use that for everything. Trailers included.
2008 wildwood le 19BH
Tv 2018 F150 screw 3.5EB
Retired UNC Charlotte engineering professor.
01-05-2020, 10:17 PM
#30
The coupons are in many magazines, NRA rifleman, our electric coop monthly and others. Typically 20% off.
Msg me your address if you can’t find one and I’ll send you one.
I’ve had my hf torque wrench for over 5 years, no problems.
01-05-2020, 10:50 PM
#31
This 200 lb/ft Snap-On torque wrench in my tool box is from the 60's and still maintains calibration. I ALWAYS back off back to less than 10 lbs after using it.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
01-05-2020, 10:59 PM
#32
I use my ryobi impact to set torque, I let all nuts get a few clicks then go back one more time around. When I don’t have it available, I get all lug nuts tight then go back hit second time call it good
2022 Chevy 3500 Diesel SWD
2022 Columbus 329 DVC
01-05-2020, 11:29 PM
#33
In case you missed it, the $20 Pittsburg brand from Harbor Freight will be 50% off starting Friday through the weekend.
Yep, I never walk out of there without extra goodies.
01-06-2020, 09:12 AM
#34
Plus you can always pull up a 20% off coupon on your phone. Just voice search on harbor freight coupon.
01-06-2020, 09:17 AM
#35
X2!
The phone app puts coupons right at your fingertips always!
Or just pull up their coupons from their web site...
H arbor Freight Digital Savings and Coupons
01-06-2020, 10:56 AM
#36
Harbor Freight torque wrenches are guaranteed for life. No receipt needed.
2019 Hemisphere 272RL
2015 Ford F250 6.2L
2005 Jayco Bantam Flier
Hensley Hitch
01-06-2020, 11:07 AM
#37
Although a lot of suggestions followed on how to find HF coupons, I'm pretty sure CNYCamper has no trouble. "Rare", in quotes, was probably just a bit of humor.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
01-06-2020, 11:47 AM
#38
As a retired Home Depot Department Supervisor, I am a big fan of Ryobi tools.
I'm sorry, but that is not what the Impact Driver is designed for. You do not have a clue as to how much torque you have applied!!!
01-06-2020, 11:58 AM
#39
I used to have harbor freight torque wrenches. That is until I was doing suspension work on my car and snapped a fastener. Turns out it was off by over 50%
I threw them all away and bought CDI which are made by snap on. I own 5 different torque wrenches of various sizes and types. For the trailer, I bought a cheaper wrench since lug nuts don't need the exact precision but it's way better than HF.
01-06-2020, 12:01 PM
#40
If you insist on using your impact, get some torque sticks.
