01-16-2020, 03:21 PM
#121
Originally Posted by NJKris
Not in NJ! I don't think I've ever seen a tire monkey use a torque wrench here in the many tire shops I've been to. Here, you're fortunate if they replace all the lug nuts!
You're allowed to tighten your own lug nuts in NJ? I'm surprised.. I know it's an issue to pump your own Gas in some areas.. LOL [emoji6]
01-16-2020, 04:04 PM
#122
I will do my part to keep this going, even though I have nothing to contribute.
Do I hear 125.....going once, going twice.
01-16-2020, 10:08 PM
#123
Originally Posted by AbdRahim
Many I have been to use the air wrnch. I don't know if they are calibrated or not.
They can't be. The only way you can control the torque using an impact gun is to use torque sticks.
01-16-2020, 10:44 PM
#124
Torque wrench
Originally Posted by babock
Yep...I actually watch and talk to the person installing the wheels to make sure they use a torque wrench at the proper torque.
Do you watch them go look up the torque specs for each make and model they put new tires on as well. If torquing lug nuts was as essential as this forum makes it out to be. Then car manufacturers would place them next to the jacks and charge 20% over their price on every car.
2022 Chevy 3500 Diesel SWD
2022 Columbus 329 DVC
01-16-2020, 11:03 PM
#125
I tell them what they need to be!
Discount tire/Americas tire actually puts the torque value on the shop ticket so that the installer knows what the torque is before hand. They have it all in their data base.
01-17-2020, 06:07 PM
#126
Dimensional Metrology
Last day as a Calibration Metrologist! Even Snap-On 2% to 4% clicker style fails when new! Not good enough for GM. We test & recalibrate as found. Anyways I retired today. Clockwise is calibrated, not CCW, at least on clickers, only dial types. Newer products lug nuts are at higher torque than older axles. Refer to the axle supplier for proper pound/feet. Yes load is stated before the distance, like Newton/ meters. Try 110 ftLbs (old school I know). And always check after changing a tire after 20 or more miles. Former CCT (Certified Calibration Technician). Nothing I said is sanctioned by General Motors and is my own option.
01-17-2020, 06:17 PM
#127
I would think GM would be using preset torque drivers, not a torque wrench.
If you're pouring, it's half full.
If you're drinking, it's half empty.
01-17-2020, 06:21 PM
#128
And congratulations on retirement, I'm a Metrologist as well. Dimensional inspection of machined, welded and fabricated assemblies.
01-17-2020, 07:14 PM
#129
Trailer Park Supervisor
Congrats Diver Dan!!! You made it!!
Yes, I drink the water!
01-18-2020, 05:39 AM
#130
At least you're "honest"??? lol Come on down. Going to Cape Henlopen March 20 for a couple nights just to get the TT in shape for the summer.
Mike
Mike Gray
Forest River Wildwood
2017 27 RKSS
2015 Sierra SLE 5.3 V8 4x4
01-18-2020, 08:30 AM
#131
I'll have to check my schedule. I'm a bagpiper, and March is the high holy season for me, usually working every weekend, especially that close to St. Patricks's Day.
01-18-2020, 08:41 AM
#132
I am a member of the “torque is important” crowd. I bought a new high end 5th in 2003. Checked lugs with my torque wrench and the “click” occurred. My torque wrench had been tested by the NIST certified metrology lab where I worked. The lab guys gave me a calibration card for set vs. actual. Yes, I always store at minimum torque setting, per the manual.
Checked lug nut torque over many miles, and never went below specified torque (1 click). Stopped while going west into Oklahoma and had a soft tire. Increased pressure, checked it again at next rest area. Low again. Loosened lug nuts with breaker bar, put on spare, was torquing lugs in the star and step manner (50/75/100/etc) and one lug bolt broke off at far less than specified torque. Decided to continue with 7 of 8 studs. Pulled in for fuel about 40 miles later, checked torque and another lug bolt broke off. Fortunately, there was a campground next door. Friday afternoon at 16:45. Called 5th manufacturer, they advised there was a Dexter parts center in OK city. To shorten story, soft tire due to cracked cast aluminum wheel, Dexter logistics manager answered phone at 16:55 and had all my studs, nuts, seals at his house Saturday morning. I did labor. The studs on the other 3 wheels were way over-tightened. I replaced all the lug bolts.
Also, when I was first driving, I went to tire shop (where Dad did all his business) for new tires on my Austin-Healey. Tire monkey broke 3 lugs off, 2 on one wheel of 4 lugs. Shop would do nothing. Dad came with trailer, we took car home, replaced all the lug bolts. That shop lost all his business.
Maybe my Mechanical Engineering degree and a focus on metallurgy/strength of materials has something to do with my torque focus.
2018 Surveyor 264RKLE
Retired
Location depends on weather and state plandemic rules.
Most coincidences are carefully planned
01-18-2020, 01:10 PM
#133
Checking an already tightened lug nut with a torque wrench is pretty much worthless since the torque wrench is going to click if the fastener is already tightened to tight.
01-18-2020, 01:15 PM
#134
half worthless. At least you know it's not under tightened!
01-18-2020, 01:22 PM
#135
true
01-18-2020, 01:54 PM
#136
When one checks the lug nuts 50 miles down the road after a tire replacement, isnt tightness (and not over tightness) what is supposed to be checked?
Cant believe this thread is still going, but I'm still learning from it!
01-18-2020, 04:11 PM
#137
Exactly!,... and if you do back it off and re-torque it every time you'll never know if it is "holding" a prevailing torque or not, until of course you have a catastrophic failure on the highway. The you get an "ah hah" moment.
2016 Salem 27RKSS
01-24-2020, 04:15 PM
#138
Of course then there are the old ones. I’ve had this since I was a teenager. Same box too as if you couldn’t tell.
2008 wildwood le 19BH
Tv 2018 F150 screw 3.5EB
Retired UNC Charlotte engineering professor.
01-24-2020, 04:19 PM
#139
That looks like the ones I used on aircraft in the Marines.
01-24-2020, 04:30 PM
#140
I've had one of those for 40 yrs, but it's a pain trying to put 140 lb-ft on it pulling from the side while trying to actually see the pointer from straight out. I finally bit the bullet and got a click-type about 5 yrs ago. Makes it a LOT easier.
2011 Traverse LT, 3.6L, FWD
