Old 12-08-2012, 05:10 PM   #11
VinceU's Avatar
Originally Posted by jim44646
Junk I just threw one away. Not covered under hand tool warrenty.
X2. Wouldn't wanna trust my coach to a $10 wrench, ever seen a truck wheel come off?
Old 12-08-2012, 05:56 PM   #12
Buying and using torque wrenches can be a concern. Cheap torque wrenches as well as expensive ones can be inaccurate. They can be as much as 20-30% off. What can you do??? Don't buy cheap. Cheap will almost guarantee that the torque won't be accurate. So what can you do?? If a TQWR has a range of 10-100#'s it will be most accurate from about 30-80#'s or in the mid-range. Actually the beam style are usually more accurate than the click style and they are cheaper. Their down side is reading them when you torque lug nuts 60-125#'s. A good engine tech will have 1/4" Drive inch LB, 3/8"-D 20#-100LB, and a 1/2"D 50#-200#. A good TQWR will cost you $200-$400. If you are only torquing lug nuts and a few other larger items a mid price range $60-$100 will work quite well. We don't need the really that good stuff. Those of you who have done well with the cheap stuff here's probably why. What's most important when torquing lug nuts is that they are all tight enough and close to the same. If your wrench is 30#'s off that's probably OK because all the lugs will be 30#'s off. That concept will not work on today's aluminum engines. Equal torque on disc brakes is critical. One lug off by 20#-30#'s will warp a rotor. Most of us don't have disc brakes on our TT's. Get a mid-priced wrench and always loosen the torque setting when finished. Make sure the threads are clean and they can be lightly oiled. Lock tight is not necessary if the bolts are the correct rating and they are torqued properly. Just remember that the bolt stretch is what holds the parts together. Under tightened and it will come apart. Over tightened and you might exceed the bolts tinsel strength. JMTCW
TeJay
TeJay is offline   Reply With Quote
Old 12-08-2012, 06:15 PM   #13
Guess I'm fortunate, mines right on the money. I guess I'll see how long it lasts.
grayfox is offline   Reply With Quote
Old 12-08-2012, 06:22 PM   #14
fast murray's Avatar
How do you know it is right on the money? A buddy of mine has a very nice Snap-on that I believe he says gets reacalibrated periodically. We had to borrow a craftsman at the racetrack once and he said he'd it was so far off that he'd be better off with a breaker bar.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 12-08-2012, 06:22 PM   #15
Twisty's Avatar
"...expensive ones can be inaccurate. They can be as much as 20-30% off."
I must disagree with that. Many "expensive" torque wrenches are guaranteed to be within .1% to maybe, 2% accuracy.
I got lucky when I bought one. I decided I wanted to get one and went to Baxters auto parts store. The tag on the shelf - $90. The scanned price at checkout - $60!! HaHa!!
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 12-08-2012, 06:27 PM   #16
Take your torque wrench to a shop that can check the calibration on them and you will find the cheap ones are extremely inaccurate. Wrenches within 1% are expensive. Remember, if the specs call for 100 lb/ft torque and the wrench is only accurate to within 10%, you can have one lug at 90 and another @ 110.
Old 12-08-2012, 08:00 PM   #17
So far so good. I had my 5'vr in for some warranty work and checked it against one of the techs wrench's. That's probably as good as it gets for me. I wish I had the luxury of having a real professional check it, but I don't. That's just the way it is for me.
Old 12-08-2012, 08:03 PM   #18
bob213's Avatar
To repeat what TeJay said...store them with the pressure off the torque setting. Storing at close to "0" will help to keep them accurate.
bob213 is online now   Reply With Quote
Old 12-08-2012, 08:24 PM   #19
X-2... so much can happen with these things. You sometimes wonder if any of them are perfect. Take care of your stuff... handling and storage.
Old 12-08-2012, 08:28 PM   #20
Coot, I like your Twain quote in your sig.
