Old 07-11-2013, 09:09 AM   #21
Originally Posted by OldCoot View Post
The torsion axles on trailers have the benefit of being as close to independent suspension as possible, whereas the spring suspension does not as the wheel that encounters a bump automatically transfers some load to the other wheel via the center walking beam.
Well, that is simply, and completely, wrong.
The loads on the axles of a tandem spring suspension are always equal, load is not transferred from one axle to the other.
Odd mistake for a mechanical engineer to make!
bakken is offline   Reply With Quote
Old 07-11-2013, 09:13 AM   #22
The loads on the axles of a tandem spring suspension are always equal.
No mistake, fact. That's what the walking beam is designed to do is transfer load.
Old 07-11-2013, 09:18 AM   #23
Nope, it is to share the load, not transfer it.
Simple mechanics 101.
Old 07-11-2013, 09:20 AM   #24
Dave_Monica's Avatar
Bakken and Old Coot, can we stay on topic which is torsion suspensions!
Dave
Old 07-11-2013, 09:28 AM   #25
Dave
Yes, indeed.
Not sure how this spring debate got injected into the discussion.
Back to my problem, I have given some thought to putting a shim under the rear of the axle mount, on the "lazy" end, which would drop that tire down to the same level as the other, thus hopefully equalizing the loads.
That would be the inverse of what happened when the camper was new, when the front of the mount slipped down, allowing the tire to rotate up and overload the other tire.
I have never been a real fan of this setup.
Old 07-11-2013, 09:33 AM   #26
And I guess that is an answer to dcheatwood, in that one can "adjust" the torsion axles, if you are willing to put shims in between the mounts and the camper frame. But that is far from the ideal answer, as you wouldn't want to just stick a washer in one end. The mounts are not all that strong, as we witnessed on another thread where the bolts ripped right through the axle mounting flange.
Old 07-11-2013, 09:40 AM   #27
Why not talk to Al-Ko about the problem and get some input from them.
Dave
Old 07-11-2013, 09:47 AM   #28
daydreaming about camping
jeeplj8's Avatar
when it comes to droop, what is the limiting factor? In a leaf spring suspension the limit is the physical travel of the spring shackle when the spring is un-sprung. As spring rates are not usually held at a constant over time, leaf springs will have different droop because the physical spring will deform.
On these trailer torsion axles, is the rubber bushing the physical limit of droop, or can the axle rotate down until metal contacts metal? My guess is that is the bushing.
In that case I would expect there is enough manufacture tolerance in bushing shape and size that you could get different droop. though 1 inch of travel seems like a lot.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 07-11-2013, 09:49 AM   #29
dcheatwood's Avatar
Item 3 in the attached list from alko sort of implies that there is some adjustable aspects to the torsion axle
. But this is way over my head. I just tow em. :-)
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 07-11-2013, 09:54 AM   #30
Dave
That would probably cause even more frustration!
