08-21-2017, 01:35 AM
TPMS
I just had my 2nd valve stem failure.
I have the TST507
Rubber Valve stems
The stems are not that old; are these possibly the reason for the failures?
I am going to convert to rigid valve stems.
08-21-2017, 08:38 AM
Yes.
08-21-2017, 07:09 PM
And why do you say Yes?
08-21-2017, 07:14 PM
The centrifugal weight of the sensors cause the rubber to split. To use any that screw on a stem you need metal stems. Sorry, but that's how it is or keep replacing the rubber ones.
08-21-2017, 07:25 PM
Had to have four rubber stems replaced on my trailer with metal.
08-22-2017, 04:32 PM
Lord I have more miles on truck, 125,000 miles so far plus truck before this truck. All with rubber stems, never a problem. Metal stems came on this camper but rubber stems on 3500 Silverado. Have TST 507 non flow through
08-22-2017, 04:40 PM
We are talking about the trailer. 507 CAP style.
08-22-2017, 06:07 PM
You are lucky. Reading all the different posts on here about problems with the screw on sensors on rubber stems having problems, I dont think is worth the chance. A shop I go to for repairs I cant do, and also rents RVs told me to use the steel stems just for that reason. I have known him for years and trust his advice. Another problem with rubber stems is the tire pressure. Most are not rated for higher pressures and can blow out with a tpms attached. But thats what I read here and was told, so I dont have a problem using the metal stems.
08-22-2017, 06:47 PM
It's kinda of funny but the tire shop where I buy my tires at has never put metal stems on rims and tires is all he sells and he sells a lot of tires. I speed on the truck too, on the interstate 75 to 80. I feel lucky I think I'll play the lottery, might win that 700 million
08-22-2017, 06:52 PM
A lot also has to do with tire pressure. Guy I go to also works on trucks. I don't have on my pickup but I do on the trailer w/tpms.
08-24-2017, 10:18 AM
I have the 507 CAP System
Per Mfg & verified by CSR rubber stems are OK on this system. I'm still thinking of switching over to the metal stems due to my luck.
08-24-2017, 10:19 AM
I'm running 65psi
08-28-2017, 10:04 AM
Truck System Technologies Rep
TST
mfMcFroggierPo,
Hi its Mike with TST. Our TST 507RV Cap is approved for Rubber Valve Stems, and many people use them with no problem. I am surprised you have had this happen not only but twice. I would switch to a metal stem. At the end of the day a metal stem is better than a rubber stem, less probability of leaking, more durable.
Please let me know if you have any questions.
I am always available on my direct cell phone at 210-420-0132
Thank you,
Mike Benson
TST Sales Manager
Originally Posted by mfMcFroggierPod
I'm running 65psi
