Old 06-20-2012, 07:42 AM   #21
Originally Posted by B47 View Post
Thanks - I haven't had a chance to look at what you said here, but I just called Daryl at Tire Traker to ask him. Daryl was not there, but his assistant said that if I wanted to check my cold psi readings the next morning that all I have to do is turn the monitor on and wait 20 minutes. After that period the last recorded psi readings would be displayed.
This is not fully explained in the manual you receive with the system, but they have included an extra supplement that explains this feature.
So while this is not "real time" information it will at least let me know what my cold psi readings from the day before were.
I feel better.
Real time report (24) hrs old. I have had tires go flat in a shorter time span. Knowing that my tires were OK the (Day before) is a little late! Youroo!!
youroo is online now   Reply With Quote
Old 06-20-2012, 11:29 AM   #22
B47
Originally Posted by RvBill3 View Post
The TST system gives you cold pressure readings in the morning. Turn on the monitor, wait a few minutes for each sensor to send an update to the monitor and you have your current reading displayed without moving. Each sensor sends updated info about every 5 minutes, unless it detects a change then it updates immediately. So you never have to wait more than a couple of minutes in the morning. The new flow through sensors make it easier to add or subtract air if needed but you should never have to take a pressure reading through the sensor since the monitor always displays the current reading-whether moving or parked.
I am starting to realize that my Tire Traker tpms does the same thing - only according to them the monitor takes 20 minutes to wake up before giving cold psi readings (see my previous post). As I also stated in one of my earlier posts, the fancy manual you get from them states that they work while the vehicle is "in motion." That is what got me to start thinking.
However, and I do not have the manual here right now, Tire Traker said that they discuss this feature in a supplement to the manual. I will have to read that again.
Still - the ability to service the tire without having to remove the sensor as with the TST system would have been enought for me to purchase that one.
Thanks for the information and I will keep you informed.
Old 06-20-2012, 11:32 AM   #23
B47
yeah - it is not my real definition of "real time" either - but it is the best I can do.
Old 06-24-2012, 12:22 PM   #24
Too old to be too smart
SpringerPop's Avatar
Originally Posted by MilCop4523 View Post
The flow through update allows you to put air into a slack tire without removing the sensor and having to reflash it.
I have the 507 "external" (non-flow-through) units, and there is no need at all to re-flash anything when merely adjusting pressures.
Simply use the "key" to remove the sensors, add or subtract pressure, and use the key to re-install the sensor.
The alarm will go off as soon as you unscrew a sensor, and will beep while you are adjusting pressure, but go off as soon as the sensor is replaced. It will have the new pressure immediately displayed.
The only time that any re-programming would be necessary is if you moved a sensor to a different location, were adjusting the alarm parameters, or were adding additional sensors to the system.
I really like this new "safety device", and will be getting additional sensors for the truck.
Pop
2005 Terry 250RKS, perfect for the two of us and the pups.
It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 06-25-2012, 09:36 PM   #25
FR28footer's Avatar
Pop
Good to know as ours just showed up. We leave on a trip tomorrow morning but I am going to program them and put them on once we get there.
Just upgraded to new 15" Maxxis tires last week so we should be good for the 200 miles.
That way i can make sure the sensors are on right and not leaking or not responding.
As you said, another good safety feature and peace of mind.
2012 Silverado 3500HD, 6.6L Duramax
Montana Big Sky 3625RE
Two Field Bred Springers
FR28footer is offline   Reply With Quote
Old 06-26-2012, 02:44 PM   #26
B47
tpms readings
OK - I installed my new Tire Traker C400 system on my Silverback 29rk and am wondering what to make of my first experience with it.
Here are the facts:
1. The FW was hauled 64 miles from storage to my dealer for some work.
2. The FW was not loaded - prettry close to factory dealivered weight.
3. The outside temperature was between 80-85 degrees F during the 1.5 hour pull and the speed never exceeded 60 MPH.
4. The following readings were on the monitor when we arrived at the dealers:
Left Forward - 87.1 PSI and 93 degrees F
Left Rear - 90.8 PSI and 93 degrees F
Right Front - 84.6 PSI and 75 degrees F
Right Rear - 88.2 PSI and 95 degrees F
I am just wondering why the Right Front temperature reading was 18-20 degrees lower than the other three tire readings.
I am not ready to say that I have a bad sensor on the Right Front at this time as this is the first time I have used it.
I also am keeping a record of all my future trips and will be able to see if the Right Front temperature reading is consisently lower than the other three.
In addition, I am comfortable with the PSI readings on all four tires. My baseline PSI setting is 80 PSI.
I did not lower my cold PSI readings before installing and programming the sensors the first time. All four cold PSI readings were 55 PSI.
Any comments?
Old 06-26-2012, 07:56 PM   #27
Rsgtivr6's Avatar
Maybe take readings for one trip, mark and then swap sensors around and see if the readings change. That will tell you if they are accurate or not.
TV: '17 Ram 2500 Big Horn CCSB CTD 4x4
TT: '18 Wolf Pack Limited 325Pack13
Tow Acc: Andersen Ultimate Hitch 2 goose ball mount, AirLift 5000 bags and HD compressor system
Rsgtivr6 is offline   Reply With Quote
Old 06-26-2012, 08:58 PM   #28
Does everyone here have metal valve stems as recommened by TST? Mine are rubber and I'm not sure if I'm getting one until I switch out the valve stems.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-26-2012, 09:41 PM   #29
B47
That is what I am planning to do - if the Right Front temperature shows to be that much lower after my next trip, I will swap sensors and see what happens.
Old 06-26-2012, 09:43 PM   #30
B47
I have brass stems and that is what Tire Traker recommends.
