Old 10-15-2015, 07:02 PM   #21
And I think that's because the sensor 'turns off' when you remove it.
That's the way mine works and that's OK because at least you know from the "0" reading that something is amiss.
If it just keeps flashing the last valid reading when missing data, (because of out of range or dead battery or wheel in never-never land) it isn't doing much good.
Mine shows 0 psi and beeps until I press the silence button..
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
dalford is online now   Reply With Quote
Old 10-15-2015, 07:47 PM   #22
gashog's Avatar
Originally Posted by D_B Travelers View Post
We purchased the 507 for our 35' Windjammer and found that we had to mount the receiving unit on one of the TV back windows to maintain contact. Mounted on the windshield it kept dropping one or two sensors. After moving it, basically 4' closer, we haven't had it drop a sensor one time. LOVE the unit, and after seeing about 4 RVs damaged severely by a blowout during this summer's trip, really glad we purchased one. Peace of mind knowing what the tires are doing! That said, I have also found it retained the last readings for a while when we drove away from the RV and agree it is just keeping the last reading instead of blinking, which it should do.
Mine came with the repeater/booster which I installed in the nose on our Windjammer, I've never lost a signal and I keep my monitor down in the open area of the console.
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 10-15-2015, 07:57 PM   #23
Originally Posted by dalford View Post
Maybe you need to get a monitor to monitor your monitor..LOL
Yeah!! LMAO!!
2017 Berkshire XL 40A & 2017 Ford Focus SE
2014 Flagstaff 5th Wheel - 8528IKWS (Sale PENDING )
I Built and Fly - Van's Aircraft RV-12
MartyQ is offline   Reply With Quote
Old 10-15-2015, 08:52 PM   #24
Blackhat6mike's Avatar
Originally Posted by Jim Schings View Post
As an EE and Ham Radio Licensee often working with and designing RF circuitry, I can guarantee you that if that unit picks up those TPS's at more than a few hundred yards, you have made a huge breakthrough in RF propagation.... I would wait for a Nobel Prize..
X2 As an ET and N7MIP, I agree. That would be the best RF propagation known to man.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 10-16-2015, 10:43 AM   #25
Received the following from TST. This sort of confirms the unit will not tell me there was loss of signal but confirms the "normal" alerts will alert me immediately.......
I apologize no one got back to you on your previous emails.
When you just drive away and do not dis-engage your trailer on the monitor by pressing and holding the Mode and Minus, the unit will echo the last valid signal it had, it confuses the monitor as it did not have a low pressure warning, rapid air loss warning, or temp spike, the signal just vanished. If you are hooked together and getting readings and you have a low tire or problem the system will alert right away.
If you would like to call me we can discuss this in more detail. I am available 7 days a week until midnight.
Thanks,
Mike Benson
TST Customer Service
4250 Keith Bridge Rd.
Suite # 200
Cumming, GA 30041
(770)-889-9102
info@tsttruck.com
