Old 12-14-2015, 10:12 PM   #1
TPMS and no warning tire failures
I have and use a TPMS on my fifth wheel.
The one time I had a blow out on my previous trailer, I was not using it due to the fact that it would occasionally loose contact with one tire and start beeping and drive me crazy. My DW asked, "Didn't you spend money on one of those tire monitor things?"
So now, I always use it and just reset it when it drops a signal, really no big deal. My question is from others experiences, how many times have you had a blow out with no warning from your TPMS? In other words, an internal failure that happened before limits were exceeded To trigger an alarm?
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 12-14-2015, 10:59 PM   #2
TPMS in the mail
Good question now that mine is still somewhere in AZ. Shipped the 12th and due in 16th.
I've been lucky and had no blow outs on a trailer (YET). Tread separations and old tires yes. I hope this doesn't turn out to be a waste like the forward self adjusting breaks. Just had same removed for standard adjusters when two were running hot after I had the trailer only 30 miles to the house.
Interested in this response also!
Charles & Martha Myatt
2009 Duramax w/Transfer Flow Fuel Tank
2016 Flagstaff V-Lite 30WFKSS
Almost South of the Border
whatsupchuck is offline   Reply With Quote
Old 12-14-2015, 11:33 PM   #3
I have used a Pressure Pro system on my Class A's and my various dinghies I had before my recent downsizing. When I purchased my first tire pressure unit, some 10+ years ago, Pressure Pro was really the only system available at a reasonable price. I never had any "false" alarms with my gas rigs, nor have I ever had any tire problem in all for all my travels. Knock on wood really quickly....
On my last coach, a big diesel pusher, I started having some problems with losing the link to the sensors on the dinghy as well as occasionally with my dual tires. I added an "extension antenna" to the system which I put on the bed in back of the coach when we traveled. With this extension, I never had any "false" alarms. Bottom line, I would suggest your investigate adding an "extension antenna" to your system and see it you still have the problems.
I think that these big masses of steel we drive down the road gives us all kinds of problems with the weak signal our sensors put out. And, yes, I will be putting my Pressure Pro on my new coach and dinghy this weekend.
Wayne Lee
Out West Somewhere
2016 Sunseeker 3050DS towing 2006 Hummer H3
WayneLee is offline   Reply With Quote
Old 12-15-2015, 09:51 AM   #4
Jim34RL's Avatar
I too would like to know the actual results if TPMS saves a true tire failure on a trailer?
Being a retired engineer and having spent a lot of time with sensors monitor components, I do not have a lot of faith in them. I have seen way to many false positives with sensor issue and nothing was wrong with the component that the sensor was monitoring at the time.
In fact right now I am chasing a sensor issue on my TV which dings every once in awhile. The idiot light illuminates and dings but than shuts off. I do not want to be a parts changer and just replace the sensor with out knowing the true issue. The diagnostic tool has not found any issue with the components that are being monitored.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 12-15-2015, 12:02 PM   #5
TST system
We have the TST 507 system and although we have never had a blow-out, it definitely has alerted us on couple of occasions when things were going wrong with our 5th wheel tires. Once it alerted us and showed zero pressure, and of course, I freaked out thinking we had a blowout, but it turned out to be a poncho we had picked up from the road somehow and it had wrapped around our tire or frame and was slowly unscrewing the sensor from the tire as it was flapping in the wind causing it to show no pressure.
We love our TST unit. We used to have the TireTraker, but it wouldn't show the psi and temp as we drove down the road. We had to push a button to get it out of sleep mode. The TST scrolls through my tires and I like that much better. Plus they have the flow-through sensors, which I use on my pull vehicle. TST RV Tire Pressure Monitors
Lincoln11 is offline   Reply With Quote
Old 12-15-2015, 12:14 PM   #6
TPMS
I have been using a Tireminder TPMS for approx. 5 yrs. In that time the only false alarms I've had were when the batterys were getting low. Changed battery's worked fine. Tireminder say's if it's cold new battery's are even more important. I also run a signal boost on the front of my 5th wheel.
jkweller is offline   Reply With Quote
Old 12-15-2015, 12:20 PM   #7
Enjoying Life
I recently left Las Cruces NM, after only 30 miles into the trip the TPMS system signaled that one tire was losing pressure. All tires had been checked prior to our departure and no problems had been observed. BY the time I had pulled over on the shoulder the tire was down to 25 lbs psi. The next exit was only 1/4 mile ahead so I moved the rig off the interstate. If the TPMS had not informed me about the tire condition, no doubt I would have continued driving with that tire. I have no idea what damage would have happened to the rig if that would have happened. I don't drive without them even with the annoying situation of sensors occasionally losing communications. The rig suffered no damage, except for the tire failure.
mpoulin8 is offline   Reply With Quote
Old 12-15-2015, 12:52 PM   #8
TPMS
We also have a TST 507 system. We use it on our 30ft Rocwood TT. On our first 2 trips we also had lost signals to the sensors. The beeping drove us crazy,we ended up turning it off. I called the company and told them about the problem of lost signal and that the system was less than 30ft apart from sensors which is distance they say the system will read all senors ok. They reconvened the antenna extension. I got the antenna and hooked it up to my battery on front of trailer and it works great. Have gone on 3 more trips and no signal loss. We had a alarm on one of the trips we were able to pull over and avoid possible major damage thanks to the system. I would highly recommend that TST system for any rig. It can monitor up to 23 tires which will cover your your rig and tv if yours isn't equiped with a system.
Joe-Barb is offline   Reply With Quote
Old 12-15-2015, 01:41 PM   #9
Blackhat6mike's Avatar
I also have the TST507 RV unit AND relay. Only one of the 5 times I have had tire failure did I know ahead of time and I monitor it religiously. All blowouts occurred while temps and pressures were within parameters [80-90psi and temps never above 102*]. I'm 80psi cold.
I'm not sure there could be an indication on a faulty tire that instantly has tread separation or explodes. If the tire is defective, it can still run with in the numbers and that is all the monitor can do is keep you advised. It can't fix a problem. The one time I had a side wall come undone, the monitor let me know in plenty of time to take care and get off the road before it blew out.
I strongly recommend the antenna relay unit. I mounted mine on tope of the tongue jack and used the tongue light power.
If you have a blowout with the STS system, you will know it instantly! Loud beeping and flashing red light.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 12-15-2015, 02:16 PM   #10
I have a tpms system and have a blowout with out warning. But it was not a fault with the tire I hit a piece of metal that cut a 5 inch hole into the side wall of the tire. Not much you can do about that. The system did beep saying no pressure but I was already pulling over because of the sound of the blowout.
j free is offline   Reply With Quote
tire
