Old 07-03-2016, 07:42 AM   #1
TPMS, Factory...
So I checked the TPMS box when I ordered my trailer.
this is what I got.
2015 grey wolf 27RR
2015 Chevy 3500HD
kcmusa is offline   Reply With Quote
Old 07-03-2016, 08:00 AM   #2
It has been my experiance that these wont work,the added weight ofTPM will fatigue the rubber mount in the rim,cause rapid air loss, but the TPMS will noteify you.
Big Bill is offline   Reply With Quote
Old 07-03-2016, 09:14 PM   #3
I must be in dream land, my 507 has been working 4 years now on rubber stems and not losing air pressure.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 07-03-2016, 09:20 PM   #4
Commercial Member
That is nothing more than a cheep valve cap that may change color to red if pressure is low. Of course to be a real TPMS you would need someone to run beside your trailer to watch the cap to alert the driver when they change to red.
IMO a bit of big BIG stretch from real truth in advertising to call that a TPMS.
If your dealer tries to tell you that is what the valve cap is, do a quick Google of the term TPMS and show him what comes up.Colored valve caps sell for $4 a set.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 07-03-2016, 09:22 PM   #5
Blackhat6mike's Avatar
X2 with Spock123
Been running our 507 on rubber stems for three years and no problem. I inspect them before each trip. I remove the sensors when not traveling to keep from running down the batteries.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 07-03-2016, 09:29 PM   #6
Commercial Member
I don't think the problem is the use of what appears to be a standard passenger low pressure tire valve with a colored valve cap.
I see nothing that looks like any real TPMS in the picture. Personally in my opinion, I would consider selling a valve cap as a TPMS is close to a scam.
Old 07-03-2016, 09:29 PM   #7
That is not amTPMS sensor. It is green because you have nitrogen filled tires. You need to talk,to dealer and get your sensors and monitor.
I too am running on rubber valve stems for over a year. 6000 miles and no issues..
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 07-03-2016, 09:58 PM   #8
Broke and happy
bobfa's Avatar
yes they will turn red when below the threshold rating. I bought some for a few bucks each on ebay.
bobfa is offline   Reply With Quote
Old 07-03-2016, 10:19 PM   #9
this is what I got.
Unless there are sensors inside the tires and they gave you some kind of box that they send signals to, they either ripped you off or they forgot to add the TPMS
2011 Traverse LT, 3.6L, FWD
Old 07-04-2016, 01:08 AM   #10
Moparman1230's Avatar
Unfortunately, that is their idea of a "TPMS". Green at the proper pressure and turns red when it falls below.
I too was supposed to get a TPMS. I smelled something funny when the dealer said they would "throw it in no-charge". I asked about it upon delivery and they pointed to those caps and said, "there you go!".
Ummm, nice try.
Sent from my SAMSUNG-SM-N915A using Tapatalk
"Do, or do not, there is no try." - Yoda
2017 Cherokee 294BH
2015 Ram 2500 4x4 6.4L V8 Crew Cab
Moparman1230 is offline   Reply With Quote
factory
