Old 04-17-2016, 11:48 PM   #21
Blackhat6mike's Avatar
X5 on the TST 507 unit. You couldn't ask for a better unit and the folks at TST are like family. Really easy to work with AND they will keep you in replacement seals, screws and 0 rings FOR FREE!! Just give them a call when you need stuff.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 04-18-2016, 01:10 AM   #22
benagi's Avatar
TPMS kit that wont break the bank?
Those who are using the TST 507, are more using the flow thru or non flow thru sensor. Thx, Ben
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 04-18-2016, 04:55 AM   #23
Non flow thru here.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 04-18-2016, 07:29 AM   #24
Non flow thur. When I got my 507 I could not afford to put metal stems in, it was twenty bucks to break each tire down.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 04-18-2016, 07:44 AM   #25
Commercial Member
Unless you have special high pressure stems you have zero reserve in the standard "snap-in" rubber valves which are rated for 65 psi MAX.
I have heard of rubber stem failure with the addition of TPM sensors.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 04-18-2016, 09:30 AM   #26
wmtire's Avatar
The site team has removed several posts that were extremely off-topic to the purpose of this thread. Please keep posts/advice pertained to the subject matter of TPMS systems.
Thank You...and now back to your regularly scheduled program.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 04-18-2016, 06:57 PM   #27
I guess my sensors are just floating around somewhere, I run 60lbs in front truck tires and 80lbs in rear tires with rubber stems. I have over 75000 miles on Silverado 3500. On my Cedar Creek I have metal stems in them, I run 110lbs in them. On my first Cedar Creek I had rubber stems and I ran 80lbs in them. I never had a problem, I must have put at least 20000 miles on that camper. On that camper I ran nitrogen and never put any air in camper tires. But then again I don't know much, well just from experience
Old 04-20-2016, 07:13 AM   #28
Commercial Member
110 psi cold? What size & Load Range? Would think LR-F is way overkill or you are way over GAWR capacity and possibly over GVWR too
Old 04-20-2016, 08:02 AM   #29
I don't think I will overload the camper as I can load 4,000lbs. The only way my camper is ever going to be weighed is if someone steals it and they weigh it.
