Old 04-26-2016, 02:12 PM   #1
TPMS Shopping
After reading more than a few accounts re. TPMS systems, and problems prevented, I decided to start looking around for a system. Found this article dated 2011. Not current but a place to start:
Tire Pressure Monitoring Systems
Anyone with experiences, good or bad, let's hear from you.
GT
2004 Dodge RAM Cummins Diesel New Venture six speed 4x4 crewcab
2016 Rockwood 8280WS
Two 5 year old herding dogs - that shed year round
greytraveler is offline   Reply With Quote
Old 04-26-2016, 02:25 PM   #2
Capt. Mike's Avatar
Good article...and probably still pretty relevant. After our first blow-out, we decided to get a tire monitoring system. We chose TST 507 because it allows you to add air (if needed) through the sensor without removing it. We've towed our trailer probably 15,000 miles since we got the tire pressure sensor system, without any problems. The 507's monitor both pressure and tire temperature.
If you do get a monitoring system, be sure your valve stems are metal as opposed to standard rubber valve stems. Any tire dealer or auto parts store can get the valve stems that you will need.
Good luck.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
ďIt's not how old you are, it's how you are old.ĒJules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 04-26-2016, 02:36 PM   #3
clr
I also would recommend some type of TPMS, I have had blow outs in the past and without an alarm you cannot even tell in the TV. Also I would recommend the metal valve stems. I am running the TST 507 and am very happy with it.
I did see though that there is a Tire Minder system for sale used on the classified section of the forum here you may be able to save a buck or two if you are interested in that.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 04-26-2016, 06:08 PM   #4
H2oski
X3 on everything said so far. I selected the Tire Minder system back in 2010. I think the key thing for any of the systems is for you to completely understand how your selected system operates.
Had a couple of slow leaks identified early which may or may not have prevented a blow out. Who knows, because I haven't had a blow out with the TPMS.
I think the some have issues with any system because they don't understand how the system works.
Good Luck
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 04-26-2016, 06:35 PM   #5
Mr. Dan's Avatar
If you do a Search for TMPS, you will find plentiful information already shared in several threads over the past few months.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 04-26-2016, 09:17 PM   #6
I have the 507 and I'm different, I have rubber valve stems and have never had a problem.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 04-27-2016, 03:39 PM   #7
Powerman's Avatar
X2
MARINOS
2015 PRIME TIME AVENGER 28 DBS
2016 GMC SIERRA DENALI 2500 HD
Powerman is offline   Reply With Quote
Old 04-28-2016, 09:37 AM   #8
Interesting. I am pretty sure the TST web site recommends the metal valve stems and explains why. Glad you have had no issues.
Old 04-28-2016, 09:58 AM   #9
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
I have the TST 507 flow thru system....ran it 6250 miles last year and getting ready to start 2nd year....running with rubber valve stem but I did order from Amazon a set of chrome valve stem covers to help hold the rubber stem more rigid....everything, so far , has worked fine....I will go to metal stems when we make our next tire purchase.....btw, the company has great customer service to discuss and help with any questions.
Lloyd & Kathy & Kit(19 yr old cat)
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi.
2017-65 nights/6992 mi.; 2018-7 nights/1037 miles....9 nights booked
jtownstumpjumper is offline   Reply With Quote
Old 04-28-2016, 10:06 AM   #10
Good for you, but I predict you will have a problem in the near future if you tow very much.
