Old 07-14-2013, 05:12 PM   #1
ryand's Avatar
Trail express bomb
My parents set off to Branson this afternoon...only to suffer another china bomb with their new Rockwood 5er. Feel bad as the damage report is not good.
2019 SOB Bunkhouse (Former Coachman FR Owner)
2015 Ram Bighorn 2500 6.4L
https://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 07-14-2013, 05:19 PM   #2
rattleNsmoke's Avatar
Damn. Sorry to hear that. They don't call them 'Blowmax' for nothing.
rattleNsmoke is offline   Reply With Quote
Old 07-14-2013, 05:25 PM   #3
China bomb??
2012 F350 Lariat CC SRW 6.7L Powerstroke
pwrstroke2012 is offline   Reply With Quote
Old 07-14-2013, 05:37 PM   #4
Tires...
Cacooze is offline   Reply With Quote
Old 07-14-2013, 07:57 PM   #5
ryand's Avatar
Apparently it did some major damage to the slide....obviously the tire is toast. Thinking of buying them a set of maxxis tires. So many failures of this brand makes me wonder if there are major issues
Old 07-14-2013, 08:02 PM   #6
This is really, really not necessary.
Forest River has to get the message and quit putting substandard tires on our campers.
Until then, it is up to us to tell everyone we know that buys a new camper to replace the tires, asap.
bakken is offline   Reply With Quote
Old 07-14-2013, 08:09 PM   #7
DDC
DDC's Avatar
Why don't people make a point of ordering the trailer with specific tires or if buying off the lot make the deal include brand specific tires its not like this is an unknown problem.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 07-14-2013, 08:17 PM   #8
We did not know they were going to put some pos no-name brand tire on our camper, until the day we picked it up. If we had known, we sure would have insisted they be changed.
Only the people who follow this forum know the problem, and that isn't that many in the big picture. I only found this site long after we had bought ours.
Old 07-14-2013, 08:38 PM   #9
This Forum is only one of MANY that acknowledge that there exists problems with overseas rubber. While touring a dealers lot last spring, I noticed the larger CC fivers with 7k axles all had Goodyear G614's on them. There may be hope.
Old 07-14-2013, 08:43 PM   #10
JoeR's Avatar
Same here. I didn't find out about the Trail Express issues until after I had my Windjammer for a while.
I've kept the tires covered and treated with Aerospace 303 UV protectant.
I've made sure to keep the tire pressure set at 50psi and mounted a set of TST sensors on the tires. If the temp gets up around 120, it's time to pull over and cool them down. So far, I've squeezed three years out of them and plan to replace with M8008s before next year.
Even with pressures sensors, I've seen reports of them letting go by some people.
JR
2008 Toy Tundra DC 5.7L Bagged w/LTs
Hensley Arrow
2012 Windjammer 3001W, Atriumed
JoeR is offline   Reply With Quote
Old 07-14-2013, 09:01 PM   #11
JR
120 !!!!!!!!
I don't think I've seen mine go over 95.
Do yours really get that hot?
Old 07-14-2013, 09:04 PM   #12
JR
Even with all your precautions, your tires are on borrowed time. Why risk $500-$600 for tires against $1500 plus in damage to the trailer and possibly an accident?
Old 07-14-2013, 09:05 PM   #13
JoeR's Avatar
I usually see around 95-100 degrees and the sunny side will crawl up to 110-115 degrees. If it hits 118/120 I'm looking for a pull off. It's happened twice so far. 100 degree ambient temps on those days.
Hensley Arrow
Old 07-14-2013, 09:18 PM   #14
I guess if the air temp is 100, then it is possible. But from what I recall, our tires usually run only about 10 degrees over the air temp. Any idea what your camper weighs loaded? Maybe those C-rated tires are getting over-worked at 50 psi?
Old 07-14-2013, 09:29 PM   #15
You can set the temp alarm lower if you desire.
Per the TST manual:
Also, we recommend you leave the temperature set at 157° Fahrenheit;
tires typically fail between 190°-200° Fahrenheit.
Old 07-14-2013, 09:41 PM   #16
JoeR's Avatar
CAT scales puts it right around 7K.
I plan to move up to Ds or Es when I upgrade.
Hensley Arrow
Old 07-14-2013, 09:43 PM   #17
JoeR's Avatar
Per the TST manual:
I set mine at 150 after reading the manual.
Hensley Arrow
Old 07-14-2013, 09:52 PM   #18
That might be why ours run so cool, as we upgraded to D-rated tires.
If we still had the C tires on, our temps might be up there as well.
Keep an eye on those puppies!
Old 07-15-2013, 09:11 AM   #19
JoeR's Avatar
I look them over every gas stop and with the 26 gallon tank on Tundra, I get to make plenty of those stops. I don't push the gas stops, especially out here in the Western US. When the gauge hits a 1/4 tank, it's time to find the next fuel station. It's not worth the stress on seeing 20 miles to empty.
Hensley Arrow
Old 07-15-2013, 09:30 AM   #20
Wanna Be Camper
SaskCampers's Avatar
You sure about that weight? Our 11 V-Lite 30WRLS which is the same trailer has a factory yellow sticker weight of 7223 and a gvwr of 8558 and we do not have the atrium windows. Loaded we always run a bit over 8k.
John & Deb
2011 Flagstaff V-Lite 30WRLS
